Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
Where can I get a centrifugal clutch resurfaced with ceramic?
  • 906 Answers
I would suggest you do it yourself. Stop by a truck shop and get one of the truck brake shoes that has been dis-guarded an cut the material off the shoe. You can shape it to the clutch with a sanding disc or mini grinder. Talk to your auto parts supplier about hi temperature epoxy to glue the material to the clutch
Posted on Jan 25, 2015
After relacing clutch assemly on eco sport 2015 has vibration i have line marks on the fly wheel and clutch assemly
AFTER... bummer!
One of your mating surfaces was less than perfect and should have bee resurfaced...
Now they all should be removed & resurfaced.
AND
Until you do so... that vibration will only get worse and put stress on every mating surface, seal and bearing
Sep 29, 2016 | Cars & Trucks
Kawasaki bayou klf300b atv centrifugal clutch nut removal
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Kawasaki despair not, for a mere $5 you can download another one. For more information about your issue and free valuable downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.kawasakimotorcycle.org/forum/kawasaki-atv-mule/138652-bayou-220-primary-clutch-nut-removal.html
Project Bayou 300 44 Clutch Repair
Bayou 300 Centrifugal Clutch Endplay Question
https://www.tradebit.com/filedetail.php/118245427-kawasaki-bayou-300-service-manual-repair-1986-2006
Feb 28, 2016 | kawasaki Motorcycles
The saw starts and revs fine but 75% of the time when i go to cut something the blade stops, but revs still ok. can someone please help?!
If the chain is engaged properly in the sprocket and you've got the correct tension on the chain and the chain stops when you set it into a cut, you are probably riding the saw too hard...meaning you are pushing too hard for the saw to cut and the centrifugal clutch is stopping rotation. If this is an older saw, the pads inside the centrifugal clutch are probably badly worn necessitating replacement of the assembly.
Sometimes on a smaller saw, if the chain is sharpened with an aggressive angle, the little pads start slipping are wear quickly.
If you have the chain tension tightened too much, it will bind in the guidebar and stop the centrifugal clutch from rotating.
Jan 15, 2015 | Garden
If you release the clutch pedal and it revs up before it goes and while driving the rpm gauge goes up and down is that the clutch slipping
If you are getting that amount of slippage, it is unlikely that a simple clutch adjustment will cure it. Your clutch pedal should have roughly 1" of free play from the top of the clutch pedal, and absolutely no more than 2" free play.
If you have zero free play, it "may" be possible to eliminate the slippage by adjusting the clutch, but you would have to be very lucky to get off that easy.
The slippage means that your clutch disc is most likely worn too thin and possibly glazed, as well as glazing of the flywheel and pressure plate friction surfaces. When the pedal is released, the clutch engages by sandwiching the clutch disc between the flywheel on one side and the clutch pressure plate on the other side. Strong springs in the pressure plate keep the clutch disc tightly sandwiched between the flywheel & pressure plate. Pushing on the clutch pedal releases this tension/pressure.
It's never "just a flywheel". That mechanic is bogus. All 3 parts are affected by worn or slipping clutch. Usually you don't need a new flywheel, as resurfacing it is usually fine & the normal procedure.
But you will need to replace the clutch disc and pressure plate anytime the flywheel is resurfaced.
Resurfacing a flywheel is similar to resurfacing brake rotors on a brake pad replacement (brake job).
Naturally the transmission has to be removed to get access to the clutch components, which is really the biggest part of the job.
Here's a pic of the basic clutch components:
Please rate via the helpful button if this helped in answering your question, or feel free to ask if you need further explanation.
Nov 06, 2014 | 2001 Volkswagen Beetle
Clutch..judder..1998..mr2
may need flywheel resurfaced, heat scoring is ussually the cause. or somebody replacing the clutch and not resurfacing
Nov 19, 2012 | Toyota Cars & Trucks
I am replacing the brake pads on my Kia 2007 Sedona; front and back is neeeded or just front? Took it to Kia dealer and mechanic showed me pads where very thin and needed replacement; all for $400! Heck...
If your rotors are good and fairly smooth, then a decent ceramic pad will work well. Just be aware that ceramic pads will require a slightly greater paddle pressure. They will last longer, dust up a bit less and will perform MUCH greater in stop and go traffic...
I suspect that 25 dollars per axle is a typical cost for good quality disc brake pads.
-Jim
Oct 18, 2009 | 2007 Kia Sedona LX Minivan
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
82 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
