Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire super capacity 2speed - 3/4 motor i
Frigidaire super capacity 2speed - 3/4 motor i feel the heat and see red heat inside the drum,but the drum dont run
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Carlos, thank you for your post!
Based on the symptoms you are describing it sounds like something could possibly be lodged in the blower wheel or your laundry center has a failed motor. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Posted on Oct 15, 2013
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: Frigidaire gallery washer won't change cycles
Look at my other post to you.
Posted on Oct 31, 2012
Cell phone gets hot
Probably due to lots of apps running in current and background sessions. Turn some of the unneeded apps off, and understand that as you use your phone the battery will become warm as it provides the current to the phone.
Mar 31, 2015 | Frigidaire FGX831FS Washer/Dryer Laundry...
The drum on my dryer seems to be stuck and is not spinning, the belt is on and seems to have the proper tension. Can someone help me get this dryer running again?
inspect the tumble dryer drum shaft - see image
inspect the dryer belt tensioner - see image listen for sound when electric motor is running
25302111-r0o5diaoq3uxmfwmdgmcujgm-1-0.jpeg 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-2.jpg
Dec 01, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
Maytag model lat 9605 aae fills with water but want agitate or spin out but works fine on delacate cycle thought it was timer put one on still doing the same thing
replace the motor brushes this is common it wont spin or do main cycles but easy go it does is worn brushes
take one and and check the lenght if its less than 50mm replace them
when they get shorter the motor draws more standing current etc running hotter so....
also check the vacume switch and for and rubbish inside the drum skin
Sep 24, 2014 | Washing Machines
Dryer heats want start
your belt is most likely either off the tract or broken
Sep 08, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
Barrel isn't turning.
I believe you will find the belt is broken.
There is a motor which is supposed to turn a belt, which in turn drives the drum.
If you wish to repair ir yourself, a letter to "Fixya" could cause someone to walk you through the steps.
Be blessed.
Mar 04, 2013 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Heating element
1. pop the top
2. remove the front
3. remove rear access panel, get belt off motor
4. remove drum retainer(where applicable)
5. grab belt at top of drum, using belt as handle, yank it straight up off the rear bearing mount( do not remove the screws inside the drum)
Jan 31, 2009 | Frigidaire GLER642A Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
