SOURCE: solobaric subs l7 15-inch
this should help you
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
SOURCE: bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
SOURCE: how to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
SOURCE: need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
