Question about Home
Security camera Problem with Smoke Detectors I have a new varifocal camera i put on my 8 channel dvr. it was ok last night in black and white with leds on and for the first hour after switching to color, but then it began flickering badly and i noticed that when it flickers it also has images from my other cameras feeding through on that channel. it has osd so i tried adjusting white balance and used a different power supply but nothing works. the other images feeding through on that line from my other cameras is puzzing. any ideas?
  • 68 Answers
SOURCE: Picture - Flickers/Shimmers
I think the solution to your problem is adjustment, not of the brightness but either the `contrast' which is probably too high, or the `sharpening' if your set has this function. Too much sharpness will cause a shimmering effect, especially where you see an edge between colours.(due to ringing at a very high video frequency). Too much contrast can start to turn the video signal upside down, causing noise on the peak white in the picture. Another cause is if the RF signal into the aerial socket is too large, This can be corrected by an attenuator, costing about £2. 6dB or 10dB can be tried.
Posted on Oct 25, 2006
old marine
  • 2153 Answers
SOURCE: The image veiwing window is mostly black, with horizontal
It sounds like your CCD image sensor is bad. Canon has issued a world wide technical notice regarding this, and will repair it at no cost if this is determined to be the problem, regardless of warranty.
Posted on Dec 09, 2008
SOURCE: Toshiba 50HDX82 screen flickers at the top
Replace the Hyper Board, There 11 10uf 16v cap's that go bad.
Common Problem with this set
Posted on Feb 16, 2009
SOURCE: Image flicker when viewing pictures in playback mode
You have the camera in Highlights mode.. while in playback use the up,down,right,left pad press it up and it will go through different displays like what settings you had the camera in when you took the picture then there is a graph screen... after that one is the highlights display which is what you have it on. Push up one more time to have it on regular playback mode. The manual explains this much better than I just did. If you have the manual you should check it out if my instructions dont help.
Posted on Apr 19, 2009
electrotech1
  • 1126 Answers
SOURCE: I have a 32" Vizio.
It does sound like a power supply problem, that caps may look good, but that don't mean that they are good.. You really need a ESR meter to test caps, but the tester is about 200, but from experience, I fine that the lower microfarads are the ones that go bad and look like they are fine. I repair LCD everyday at work and from what you are telling me, it is the power supply, replace low value caps, like the 1, 10 , 33, 50 farads. That should take care of your problem.
Posted on Dec 09, 2010
My swann 8-camera system, each night goes into the "no video Mode" each night and comes back on in the daylight.
It's going into ir sound like you are not supplying enough power to the cameras or you might have a timer on you system
Oct 11, 2016 | SWANN H264 8 Channel Dvr W500 Gb Hard...
Dowsing dvr 264 been working fine, just got no video on screen record lights in red are on no picture ?
Check the wires from the cameras to dvr. Animal may have chewed thru them.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 25, 2016 | Dowson 8 Channel H.264 Cctv 1tb Hdd...
Trying to set up system 1080 p. TV is 720. In setup said was incompatible. Now we have no screen to change it
You have two options: upgrade to 1080 TV's or monitors, or downgrade your security system to one compatible with your 720 screen. For security purposes, the 1080 system will offer a clearer picture when details may be of utmost importance. With that in mind, the first option would be the best.
May 15, 2016 | GW Security Complete Professional 16...
Bunker Hill security 8-Channel Surveillance DVR item#61229 keeps rebooting itself. "system initializing"
Rotorway Bunker Hill never lasts and it's the cheapest one with the worst resolution you just don't want to operate and put your life on the line with this unit
Jan 18, 2016 | Home Security
How do I change the user id and password?
you will have to get a user manual and search through that, http://www.manualslib.com/brand/night-owl
Security Cameras Home and Business Security Systems Night Owl
i cant find anything,i think you will have to contact them in the url that i just posted
Jul 05, 2015 | Night Owl K-88500C: H.264 8 Channel...
How do i find the defult sender password to set up my H.264 DVR
Open up the password browser and enter...519070 that's the Default. I have years of experience with the night-owl system.
INSKIP
Jun 07, 2014 | Night Owl Optics Night Owl Scorpion 168500...
Home Logo
56 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
