Question about Frigidaire FRU17G4JW Refrigerator
Model no.PDCS1NBXBRSS freezer door wont shut - Frigidaire FRU17G4JW Refrigerator
How to fix freezer french door that wont close or stay shut.
can you tell me how old and what's the model number of the freezer?.
cheers
Harry
Dec 20, 2015 | Refrigerators
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
Freezer is Frozen shut
Try unplugging the freezer and leave the door open for about 30 to 45 minutes. Don't forget the door is open and plug the freezer back in. Set a timer in the kitchen so you don't forget. Once you can open the drawers look inside the freezer sides to find the controller. Most models have turn dial inside.
Mar 07, 2012 | Siemens Freezers
I have a commercial freezer and I just replaced the gasket. Its the exact fit for this model and didnt have any problems installing it. When I close the door it wont stay shut in other words the gasket...
this is happening because of the new gaskets, what you do is lay something against the door or doors overnight and tomorrow they will be great. hopw this helps.
Feb 23, 2011 | Turbo Air TSR-49SD Stainless Steel...
Freezer runs continuosly, temp on control reading -8 degrees,unit never shuts off. also get alot of condensation on doors seems door heaters are not working.
Lets start with why it wont shut off. This seems most likey the thermostat. Turn down the t'stat to 1. if it doesnt shut the compressor off then recommend to replace t'stat. If you do defrost the whole freezer so that when you turn it back on it should take care of the condensation on doors
hope this was helpful
Mar 12, 2010 | Freezers
The fridge and freezer is not chilled
power to the house was shut off for repairs, when power was restored the freezer part of the fridge stopped working but the compressor still runs.
Mar 19, 2009 | Hotpoint HSS25GFP Side by Side...
Upright freezer door won't stay shut
the door maybe disaligned. Look at the the door side on to see if it has dropped a little. It may just need adjusting.
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer Door wont shut
two things i would check. first would be an obstruction in the freezer compartment. ice bin perhaps. second would be the black plastic door cams that are to help close the door. Each door has two and they are at the bottom. one on the actual hinge and one on the bottom of the door itself.
Oct 24, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Frigidaire FRU17G4JW Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
