Question about Samsung UN46ES6100 46 Inch 1080p Smart TV LED LCD HDTV
Picture does not fit screen 46uf6300 - Samsung UN46ES6100 46 Inch 1080p Smart TV LED LCD HDTV
How do i make picture fit screen? top and bottom of picture is missing
Some receivers have the ability to do this for you, for instance, all ViP and Hopper receivers from DISH can stretch or shrink the screen to fit. Most HDTvs also have this feature, independent of the type of input, using your TV remote find the button that says something along the lines of screen size, picture fit, stretch, aspect, etc. While watching a program that looks unlike the way you want it to, tap the button until the picture changes to the style you most prefer.
Mar 02, 2015 | Evesham Televison & Video
How do I reduce my picture to fit my screen
What program are you using to view picture? There may be an option on the lower left of screen which allows fit to screen. Or with some programs you can r click on picture to reveal this option
Sep 27, 2014 | Computers & Internet
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
Droid (2 GB) Cell Phone: how do i set my background to fit the hole screen?...
on every droid that i have seen,if you change the resolution of the picture to the largest,then the image will fit.If you take a picture with your droid,it should just fit the whole screen.
May 17, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
The picture doesn`t fit the screen. Daewoo DWX-28W5GB telly
Sometimes the box that sends the signal to the TV preconditions the signal to 4x3 or 16x9, depending on the capability of the TV. I always opt to the "no fit" option and allow the intelligence of the TV to fit the screen.
If you have "off air" TV signal without that preconditioning, I cant help.
Oct 02, 2017 | Daewoo DTQ-20U9SC TV
Picture doesn't fit screen on Hitachi Plasma TV
I think that is just how the settings are applied in wide screen mode a little over sized
Oct 28, 2017 | Hitachi Televison & Video
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Samsung UN46ES6100 46 Inch 1080p Smart TV LED LCD HDTV Logo
94 people viewed this question
Jerry Greenberg
Jerry Greenberg
