Question about Stealth Cam STC-P8XT Prowler XT 8.0 Megapixel Scouting Camera
Stealth cam stc-p8xt won't power on Opened it up
Stealth cam stc-p8xt won't power on Opened it up and the board is getting hot by the ground wire and it is not even on. Any ideas before I time consumingly trace the board component by component.
Where can I buy Stealth Cam G42 No-Glo Game Camera STC-G42NG?
You can buy Stealth Cam G42 No-Glo Game Camera STC-G42NG from Best Trail Cameras as it is best for providing one with the best options for oneself. You can also check out some of the PROS and CONS of this trail camera that are listed below -
PROS -
1. 10 MP.
2. Triad 3 Technology.
3. QuickSet Setup.
4. 42 LED IR FLESH.
5. Matrix Advanced Blur Reduction Technology.
6. Multi-Zone Detection Capabilities.
7. Secure Lock Password Protection.
8. Burst Mode.
CONS -
1. Heavy Usage.
Mar 29, 2017 | Cameras
Camera says nosd when the same memory card is in it from last year. Tried the other 3 from last year with the same result
Try to check if the contacts in the camera, where the memory card goes in, are still clean and shiny. Only one with a little oxide on it, can spoil the fun. Only try to clean with a dry cloth and or cotton swabs. If you use oil or contact spray, all contacts will corrode much faster.
If you have the skill to dismantle the camera, you even can go farther, and check the whole path from the memory card contacts to the maim board of the camera.
Jun 23, 2014 | Stealth Cam Prowler XT STC-P8XT 8MP...
I have a stealth cam STC-1850. Takes good pictures but will not recognize my memory card. Will only record pictures in the internal memory.
What size card are you using? This camera will only take a 2Gb card and may not read anything larger. Try a smaller Gb card
Jan 05, 2013 | Stealth Cam Ir Digital Video Deer Game...
I need the manual for my stc - z31rtl
hi well problem stealth cam get on lock up noreset on box new batter and new card not work need have repair shop ?
Sep 27, 2012 | Stealth Cam Core-Triad Equipped 40IR
Looking for a users manual for stealth cam unit
Have you tired going to the customer service site of the maker of the camera? We do not have the manual here at Fixya for this product yet.
Dec 23, 2011 | Stealth Cam The Unit 8.0 Megapixel...
My stealth cam 430ir shows all figures on digital screen and none of the functions are responding. what should i do?
Screen would work for about 30 seconds and then start acting up.
I found the two small crystals on the main board to be bad. I replaced with 32kz watch crystals and fixed it. One crystal is under the display. The other is in center of board next to a larger crystal.
Aug 07, 2010 | Advanced Electronic Support Stealth Cam...
Manual for Stc hd-400 NEEDED
Search online. Most documentation can be found using Google.
Feb 20, 2010 | Advanced Electronic Support Stealth Cam...
Stealth cam digital game camera not taking night pictures
i opened up the unit and found the wire from the cover had became loose from its soldered point, where does it go so i can resolder it.
Jul 04, 2008 | Advanced Electronic Support Stealth Cam...
Stealth Cam STC-P8XT Prowler XT 8.0 Megapixel Scouting Camera Logo
53 people viewed this question
Top Stealth Cam Video Cameras Experts
Are you a Stealth Cam Video Camera Expert? Answer questions, earn points and help others
