Question about Gemmy Lifesize Dead Head Butler
GEMMY 6 FT FRANKENSTEIN HEAD WILL NOT TURN - Gemmy Lifesize Dead Head Butler
What are cylinder head torque specs?
Tighten the cylinder head bolts in the sequence shown in figure. Using the 4 step torque turn method, tighten according to the following values.
  1. Tighten center fasteners 1 thru 6 to 33 Nm (25 ft. lbs.) . Then outer fasteners 7 thru 10 to 27 Nm (20 ft. lbs.) .
  2. Tighten center fasteners 1 thru 6 to 67 Nm (50 ft. lbs.) . Then outer fasteners 7 thru 10 to 27 Nm (20 ft. lbs.) .
  3. Tighten center fasteners 1 thru 6 to 67 Nm (50 ft. lbs.) . Then outer fasteners 7 thru 10 to 27 Nm (20 ft. lbs. ).
Then tighten all fasteners 1 thru 10 90┬░turn . Do not use a torque wrench for this step.
Feb 06, 2016 | 1999 Mitsubishi Eclipse
I have a 5 foot singing Grinch that I cannot get into the standing position. I have pushed down on his shoulders and releasing gently. I've searched for a dial on Neck to turn and cannot locate
I have a 5' Singing Dancing Skeleton by Gemmy Industries
ebookss.holding.no-ip.ca/F/support/t6410955-5_singing
I have a 5 ft tall singing dancing santa claus that was from Walmart. ... christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of ... My Gemmy Singing, Dancing Santa won't spring up into standing position.
15235022 Penguin won't dance - Document Download
codigo.no-ip.net/F/support/t15235022-penguin_won_39_t_dance
... you turn to unlock him into the standing position. good luck , I have the same problem. ... I have a 5 ft tall singing dancing santa claus that was from Walmart. ... 5 ftAnimated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the ...
I have a lifesize grinch who stole christmas(Gemmy 5 ft - Fixya
Dec 01, 2015 | Toys
A need a ac motor for the top of my xmas Disney carousel.
Look for the manufacturer's website and then get contact information for a parts and service supplier etc.
Oct 04, 2014 | Gemmy Industries Corp. Airblown 6-7/10 ft....
Animated Gemmy Dancing Frankenstein will no longer dance even though the eyes light up and the song Monster Mash is playing. What can I do to get his hips to start moving again?
To make frank stand from stored postition you push down on his shoulders to unlock his legs. My question is how do I get his him to dance again? He's also shorting some on songs, does anyone have manual?
Sep 25, 2013 | Gemmy Toys
Broken gemmy Christmas ferris wheel
I lost my adoptor for the 7 ft animated christmas ferrris wheel , where i can buy one
Aug 29, 2012 | Gemmy Life-Sized Animated Santa
I have a lifesize grinch who stole christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the sitting position..... pmaguire@cfl.rr.com
if you have the same on as I do, gently pull off his head - there is a large dial that you turn to unlock him into the standing position.
good luck
Dec 18, 2010 | Gemmy Life-Sized Animated Santa
Head bolt toqure
Hope this helps, from autozone site. Curt
Application:
Cylinder head bolt torque sequence
Note :
Torque sequence:
front | 3 1 6 |
of | |
vehicle | 5 2 4 |
Step 1: Lightly oil cylinder bolt threads & washers
Step 2: Torque to 22 Ft/Lbs
Step 3: Torque to 51 Ft/Lbs
Step 4: Loosen all bolts 180 degrees
Step 5: Loosen all bolts 180 degrees
Step 6: Torque bolts 1 & 2 to 25 Ft/Lbs
Step 7: Torque bolts 3, 4, 5, 6 to 11 Ft/Lbs
Step 8: Turn all bolts an additional 80 to 90 degrees
Step 9: Turn all bolts an additional 80 to 90 degrees
*** CAUTION ***
engine uses Torque To Yield head bolts (TTY) that
permanently stretch during the initial installation.
New head bolts must be used when cylinder head is
replaced or re-installed to obtain proper Torque.
Apr 24, 2009 | 1995 Subaru Legacy
Inflatable inflates but will not lite
I have the same problem with the snowman family - no lights or sounds - if you get an answer, please forward it on to me at donna_dsr@yahoo.com. I have emailed Gemmy but no response yet.
Dec 09, 2008 | Gemmy 4 Ft. x 6 Ft. Airblown Thomas the...
Gemmy Lifesize Dead Head Butler Logo
55 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
