Question about Haier L42B1180 - 42 1080p LCD HDTV
How do I connect a laptop to this tv? - Haier L42B1180 - 42 1080p LCD HDTV
  • Haier Master
  • 5,123 Answers
It will depend on the laptop's available external video ports. You can connect a VGA cable from some laptops to the VGA port on the TV. Then plug in a 3.5 mm audio cable from the headphone jack to the PC audio in port. (The audio connection is optional. You could continue using the laptop's speakers.)
Make the connections with the TV and the laptop off. You may need to enter the BIOS to enable the external video port. (It can be turned off to save power. The BIOS is accessed on boot by pressing a key (Esc, F1, Del) noted on the splash screen. For Win8 machines, you'll need to do a special restart.) Then turn on the TV before turning on the computer. The TV monitor should be automatically recognized for resolution and refresh rate. Next, if you have a Windows system, right click on the desktop (pick a spot with no icons or running programs). Click on Screen Resolution (or perhaps Graphics Properties, depending on the OS). Set the monitor to duplicate the screens or send data only to the TV screen.
I'm not sure if the HDMI ports will understand a computer signal. (Not all TVs can interpret the computer's HDMI signal; it is different than that of other set top boxes.) You can try the following connections.
If your laptop has a DVI output, use a DVI to HDMI cable (or adapter) to connect to the TV. Then connect the HDMI cable to HDMI 1 and use the PC audio connection as above.
For an HDMI output, use an HDMI cable. (You will still need the audio cable unless you can reset the audio signal to output on the HDMI port. Go to the Control Panel and then the Hardware and Sounds section. Under Sound, select Manage audio devices. Then in the Playback tab, make the HDMI audio the default.) For Display Port or Thunderbolt outputs on the laptop, you will need a DP to HDMI adapter.
If the HDMI port doesn't understand the computer signal, you'll need to use a converter to go from the computer's output to component video or to VGA. Then connect the converter's output to the appropriate port on the TV.
I hope this helps.
(To access the Control Panel in Windows 7 and earlier versions, click Start and then find the Control Panel in the right hand column. For Windows 8, press the Windows key + X (or access the Charms menu on the right-hand side (Win+C) and choose Settings). Then select the Control Panel.)
Posted on Oct 13, 2013
Connect jvc tv laptop so sound will come through the tv and not laptop
how is the laptop connected to the tv? and what operating system are you using please
Feb 26, 2014 | Televison & Video
Connect laptop logik tv
If your TV has an VGA input. Connect a VGA lead from your laptop to the TV. Press and hold on the laptop, the Fn key whilst pressing F4 to allow an external display to work. Set the TV to VGA in and there you are.
Oct 25, 2013 | Computers & Internet
Connect panasonic led tv to laptop
do one thing to connect ur laptop to tv is just shut the ******* lolz coz i dont knw how the **** to connect my ******* toshiba laptop to my panasonic led tv **** man lolz iam trying the same thing but this **** does't connect to dis **** tv it cost one rs.1.5 lak nd this **** make me angry sorry bro help me also if u gets to knw how to connect laptop to tv
Aug 10, 2012 | Toshiba Computers & Internet
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
Jan 07, 2012 | Toshiba Satellite A665-S6086 16-Inch...
How can I watch Television on my laptop?
you may need an external TV tuner connected to your laptop, the cable signal/connection will be connected on the tv tuner.
Let me know for any clarifications
Sep 05, 2009 | Acer ASPIRE 5720-4649 Notebook
I need to connect pc to tv (digitech video) to watch a dvd from my laptop onto my tv????
You can connect your Laptop with your TV in various methods which depends on the type of connectors available in your laptop as well as TV.
1. If your laptop as well as your TV is having HDMI ports, then buy a good HDMI cable and connect them. Simple :)
2. If your laptop as well as your TV is having VGA connect ( similar to that of monitor connector), then get a good quality VGA cable and connect them :) Again Simple.
3. If no matching port is not available as suggested in previous tips, then you have to go for appropriate convertors depending on the connecting ports available in your laptop and TV
I hope this is helpful to you :)
Aug 29, 2009 | Computers & Internet
Laptop connected to TV via 23pin cable and setup
You have to connect the laptop to the TV by using the headphone jack on the laptop.
Only then, will the sound be sent over to the TV, and automatically the speakers on the laptop will stop working.
Get a cable to connect them from the headphone jack to an appropriate input on the TV.
Hope I helped,
Tom
Jun 21, 2009 | BenQ Computers & Internet
Connecting to laptop.
You have two way to connect your laptop to your T.V. using VGA or S-video, Check your T.V. for VGA (which is standered on all Laptops) and S-video which is on most T.V., but not standard on laptops.
You also will need RCA audio to earphone jacks to get audio out of your T.V.
After you connect your laptop to your T.V. press FN and F5.
May 27, 2009 | GE 25GT240 25" TV
What type to cable should I buy to connect laptop to tv
Youre laptop would have to have a video card that has a TV-out port... And for that you would have to run a S-Video cable from the TV-out port of your laptop to the S-Video port on your TV... I assume your TV has a S-Video port?
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Haier L42B1180 - 42 1080p LCD HDTV Logo
183 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
