Question about Vacuums
Lost insrution on how to set my powertech ms 6110 timer
I have aMicromark MM9533 7day electronic timer (could be quite old), but cannot set it because I have lost my instructions. I can set the time ok, but when I try to set each day's on/off times, it...
There are eight timer on/off events, you set each of the on and off time pairs for a particular day of the week or combination of days. If it is that old, mine was bought in 1999 and just rediscovered, you should change the button battery found under the screw panel. The timer doesn't work the way you seem to be describing.
Sep 02, 2011 | Vacuums
I have lost the insrutions for my carpet cleaner
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://canada.bissell.com/images/UserGuides/9500_107.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
Thank you very much and good luck.
Apr 20, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hi, I have a crown digital timer model number cra8442. I have lost the instructions and cannot remember how to set the time. Can you help? Many thanks Michelle
Hi, push and hold the 'yes' button until the day flashes, select day with v ^ buttons. Press 'yes' again to set hour. repeat for minutes etc.
good luck
Dec 22, 2010 | Vacuums
Need directions on how to program this outdoor timer, I lost the original instructions
Is this a vacuum system? If this is an outdoor timer for a Central Vacuum system, there will not be an outdoor timer, nor an indoor timer. If you are operating a ROBOT vacuum, there is a timer on the charger. Please explain.
Nov 16, 2010 | Vacuums
GE 15086 7-day Digital Wall Switch Timer 15086 Having installed and set up timer, and put the switch from timer to off. Then, when I push the door to turn on the lamp, it does not work. Why? Thanks.
I think this is the dealy timer you have installed and if your relay is connected to the other side it becomes and switched on timer.
So I think if the timer controller is correct you must connect the lamp to the OFF relay and when the door is opened the lamp wil light up for the designated time set.
Is that so?
Sep 18, 2010 | GE Vacuums
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
I lost the instruction manual and I don't remeber how to set my timer the model is EMT757-UL
EMT757 looks very similar to Westinghouse 28449
Manual for Westinghouse 28449
http://waterheatertimer.org/pdf/28449_59_TimerManual.pdf
If this is correct timer and manual, add comment saying yes or no.
Aug 31, 2010 | Vacuums
Vacuums Logo
164 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
