Question about Car Audio & Video
I have a 400w crossfire amp, the green power light is on and the red prt light is off, everything is connected properly no loose wires but my sub still isn't working. Some time ago when the sub worked, sometimes when I turned the truck on the sub would make a loud wwhhooofff wwhhhhooofff then i would plug in my aux and could play music. Maybe a diode in the amp?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Maybe the rca cables try that they go bad and u can get new ones that are bad to
Posted on Oct 16, 2013
  • 160 Answers
SOURCE: if my jl amp e1200 is on green, but no power is going to the sub
your audio wires from the head unit have been pinched or discontected or the head unit is not putting out a signal
Posted on Dec 01, 2008
  • 4 Answers
SOURCE: Amp Turns on Fine, but no Sound
have you checked the levels on the ohms? adjust them higher if need be contact me on yahoo msgr if you need more assistance
jcbproducts-always forward
ym-jcbproducts
Posted on Dec 03, 2008
sparky1500
  • 1066 Answers
SOURCE: i have a crossfire cfa354 amp.when i try to bridge
you shouldnt bridge the 2 right channels, you should bridge the right and left together.
Posted on Mar 12, 2009
darkoh69
  • 77 Answers
SOURCE: Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Posted on Jun 01, 2009
  • 518 Answers
SOURCE: How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Posted on Jun 13, 2009
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
There's a flashing green and red light when my car is on and the sub attached to the amp is making a heartbeat like noise when the light goes green and then the light goes red right away. everything is...
Check the wires for short circuiting at the car body or speaker wires. Triple check really everything.
Make sure the connectors are 100% connected to the wires. There maybe some resitance if the amp isn't getting enough power from the battery.
Aug 19, 2011 | Jensen JXP680 Car Audio Amplifier
Hey i dont know to much about amps, but me and my friend (he knows a decent amount about amps) would plug the power into the amp and the green light would come on. Though when we plug it into the subs, the...
Are you connecting positive to positive and negative to negative from the sub to the amp? If so, try positive to positve (+) in the far left channel and then the negative to negative (-) on the far left channel to. If no luck do the same in the other channel with one sub at a time. Try one sub at a time, Dont try an connect 2 or more subs to one channel as this would cause the amp to go into protect mode (red light you describe). Usually the positive wire has either a line down the wire, writting on it or has a red seperate wire with it when wire end stripped to connect it. Hope this helps and please rate...
Mar 11, 2011 | Bazooka EL1500 Car Audio Amplifier
Alpine mrp m 1000 turns on, has a good ground, but no sounds from sub. everything is wired correctly, i have tried using a different speaker to see if its just the sub that is bad, and ive tried using my...
Is the amp in protect mode? Maybe a red light on the amp. I would also open the amp and check the RCA connections aren't loose. It's usually a solder joint. Swap the amp out as well. Or check your power wire. Sometimes amps come on when it gets remote power, but actually the power wire has a bad fuse or connection.
Oct 04, 2017 | Alpine MRP-M1000 Car Audio Amplifier
Amp has power but sub doesnt work
You say the amp has power so you mean the green l.e.d. comes on correct? If so and you don't get any juice to your sub, check your RCAs make sure they're hooked up correctly. If they are check the wires to your sub, make sure they're making good contact, if its a binding post connection to the sub it can look connected but not be i've had it happen to me before. If the l.e.d. is red, you either blew a fuse on your amp, or your sub is blown, but if you get a green l.e.d. on the amp don't worry about those. If everything checks out and you still don't get power, take your setup to a professional and have him personally look it over for you....... hope you get your bass bangin!!!
Sep 15, 2009 | Kicker KX600.1 Car Audio Amplifier
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
Green light is off and red prt light flashes once I have a crossfire 1000WT
Most likely you need to check the Fuse(s) and check all connections including any RCA's and Speaker Wire. Do that and get back to me.
Thank you for using Fix Ya!
Good Luck!
Don't forget to rate the overall satisfaction of this response or solution.
Feb 01, 2009 | Crossfire VR1000D Car Audio Amplifier
Fusion sub n amp dont work
didi u check ur fuses in the amp..if not there check the fuse under the hood on your power wire.i had the same problem
Jul 27, 2008 | Car Audio & Video
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
