Question about Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model
Craftsman zero turn model# 107.27774
Ran fine yesterday today it wont start when you turn the key it clicks 12 volts on the yellow (solenoid )wire when you turn the key but when you jump the solenid it will crank but the blades will not engage. safty switch keeping it from starting and blades engaging? thanks
  • 24 Answers
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Posted on Apr 24, 2009
Toro timecutter won't turn over with key
Sounds like the solenoid is bad. Most solenoids connect positive + from the battery. One side will read 12 volts (with the black wire of a test meter or test light. (The side connected to the battery). Energize the solenoid (loud click) And with the key held, check the other side for voltage. No voltage, bad solenoid. Be careful when you buy a replacement. Many look the same but do different things.
Apr 09, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Would a bad solenoid cause a clicking sound when you turn the key but starter want engage
Yes and no. If you have a test light or voltmeter you could check the heavey wire which comes from the solenoid and goes to the starter. While attempting to start the machine if you have 12 volts or better(or the test light is nice and bright) on the starter end of the wire than the starter is at fault. If however there is no voltage at the starter and the solenoid is clicking your fault is likely the solenoid. This is all assuming your battery is at 12 volts or better and fully charged.
Feb 23, 2013 | Craftsman Garden
Starter not getting voltage
The starter gets powered by the solenoid which is energized when the ignition key is turned to the start position. Look at the picture below and read the sequence of operation below it. Once you find out what is NOT happening - you can troubleshoot back from there.
The IGNITION KEY SWITCH is connected by a small wire to the terminal in the GREEN circle on the SOLENOID. The battery is connected by a thick, heavy cable to the terminal in the RED circle of the SOLENOID. The terminal in the YELLOW circle of the SOLENOID is connected to a thick, heavy cable that goes directly into the STARTER MOTOR.
The -12 volts from the battery is connected to the car's engine, frame and body. The entire car has -12 volts available to all electric (and mechanical) parts, so only one wire is needed to energize those parts.
When the key is held in the START position, +12 volts from the battery is passed through the IGNITION SWITCH to the GREEN terminal on the SOLENOID. This causes the SOLENOID to (1) become energized, (2) internally physically connects the +12 volts RED terminal to the YELLOW terminal and (3) physically engages the STARTER to the engine's flywheel. When this happens, the +12 volts from the battery appears on the YELLOW terminal; and directly into the STARTER MOTOR. The STARTER MOTOR spins. Since it is engaging the flywheel, the flywheel turns too and the engine attempts to start. Once the engine is running, the key is released. The SOLENOID (1) becomes de-energized (2) opens the physical connection between the RED and YELLOW terminals, (3) disengages the STARTER MOTOR from the flywheel and the STARTER MOTOR stops spinning.
I hope this helps!
Aug 23, 2012 | 1998 Honda Accord
Have a 1994 grand jeep cherkeet larado and it wont start started fine yesterday check battery , fuses all good
you may have a bad starter solenoid.using a test light at the starter the light should be lit on the large wire terminal and with someone trying to start the car yhou should have the light on when the key is turned to the start position.it you have a volt meter you should have battery voltage on the large wire and the same on the small wire when the key is in the start position.you can try tapping the starter when someone tries to start the car.if it starts then replace the starter.its the most common problem.
Dec 07, 2011 | 1994 Jeep Grand Cherokee
1988 460 motorhome starting problem
When its hooked up, you should be able to put 12 volts on the little stud on the solenoid and it should start. One large stud will have 12 volts on it, so just jump it right there. Did you get the wires in the right place. The solenoid should have 1 large wire going down to the starter. Be sure the battery cables are clean and tight ( both ends) Check battery voltage when cranking, should go to 10-11 volts. Check voltage between negative terminal on battery and engine, should be ZERO when cranking. The solenoid has 2 large studs, make sure the battery positive wire and all the other wires are hooked to this stud, the other large stud should just have the wire going to the starter.
Jan 23, 2010 | Ford E-350 Cars & Trucks
Solinoid not engaging when i turn the key to start i have a new battery also
check battery /cables also check for 12 volts at the solenoid when you are trying to start with key switch . If you have 12 volts at wiring but solenoid wont engage then you have a bad solenoid. If no 12 volts at wiring to solenoid then the problem is between the battery and the ignition switch and or relays to the switch and or a fuse or bad ignition switch !! Good Luck swampratt200
Jul 05, 2009 | 2002 Hyundai Accent
My 2006 troy-bilt superbronco wont start. There is only a clicking sound that comes from under the seat. Batery is fine and the starter is new.
There is a "starter" solenoid that closes when the ignition key is turned to the start position.
Follow the positive (red) battery cable from the battery post to the solenoid. If you have a 12 volt test light or volt meter, check to see if you have 12 volts on the battery side of the solenoid then turn the key to the start position and see if you have 12 volts on the starter side of the solenoid.
I believe you have a starter solenoid that has gone bad.
Good luck, let me know.
Regards,
Jun 30, 2009 | Garden
It won't start
do you have power to the solenoid?? with the key on there should be 12 volts on one side of the solenoid then when you turn the key to start it should send 12 volts out the other side to the starter
Apr 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
12 volt supply problem 1987 chevrolet r30
i ran into EXACTLY the same problem on an 86. i kept forkin' around and finally went direct to the starter and bingo it started. to this day it is still working and never happened again. i have absolutely no idea why. by the way--that was almost 2 years ago. might also be corrosion between the battery cable @ the starter, and the wires that go to the waring harness.
May 15, 2008 | 1987 Chevrolet R30
Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model Logo
594 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
