Question about Dell Computers & Internet
Blue screen - Dell Computers & Internet
  • Dell Master
  • 27,725 Answers
BSOD Bluescreen of death can be caused by a number of things
If the PSU power supply units fan is not working the PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram or the RAM modules might be dirty.
Might be getting hot
Check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Then reseat the modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
You might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to
compatible ram also you will have an option to scan your system
you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste.
Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty.
Computers need all power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
you might have a dirty graphics card if you remove your graphics card clean both card and socket restart your computer then reinstall it this should activate found new hardware wizard
Posted on Oct 14, 2013
Dell inspiron 570. 1 beep on start up. black screen. 1 light on the front
if you need support for your Dell inspiron 570, Blue Screen of *****, Fix Blue Screen Errors, Blue Screen Error in Computer, Blue Screen Error in Laptop, Dell Technical support Number, Dell computer support, Dell laptop support Number 1-800-204-4427 (toll-free) and more... http://www.delltechnicalsupportphonenumbers.com/blue-screen-of-*****
Jun 24, 2017 | Dell Computers & Internet
My computer keeps going to the blue screen showing the message 0x0000001e,oxffffffc05,0xfffff80003dcd7da,0x000000000000000001, 0x0000000000000018, bios update, disable bio memory such as caching or...
Maybe you can try the following solution... Blue screens are typically caused by software errors in device drivers: in Windows systems by poorly written device drive , They can also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer blue screen,too. They can make our computer run into blue screen error and prevent us from working, studying or playing games online. Now, let's learn to fix blue screen error as follow steps together. You will find how easy it is to solve the problem.
Step 1.Burn a bootable CD/USB by Fix Genius for fixing blue screen error.
Step2.Change BIOS of the computer to boot from CDROM or USB Device Drive.
Step3.Fix blue screen of death with the created CD or USB easily.
Computer blue screen exists in kinds of windows system, and the solution is available for windows 7 blue screen, xp blue screen, vista blue screen and even windows 8 blue screen, etc. Laptop blue screen seems more likely to occur as its insufficient configurations. But it isn't real and if we can keep using our computer in a good way, they can both be health. After,blue screen of death is no longer a horrible disaster when it occurs to us, just use the methods above and we can solve the problem soon.
Nov 10, 2012 | LG AKB72915206 REMOTE CONTROL
When i turn on my pc only blue screen display on my screen
I hope you may solve your problem soon.By the way, the software is in Christmas promotion.
Oct 29, 2012 | Asus Eee 701Sd Notebook
How-To Repair Blue Screen and Safe Mode
if u wanna rid of the blue screen follow this link
http://ezinearticles.com/?Blue-Screen-of-Death---How-to-Remove-the-Windows-Blue-Screen-of-Death-For-Good!&id=1752190
Mar 03, 2010 | Computers & Internet
Blue screen of death
Try to reinstall windows by repairing it.
Mar 04, 2008 | Gateway M275 Tablet PC
Blue Screen of Death
r u sure the monitor is causing the blue screen of death?
I would try another monitor to verify.
Dec 25, 2007 | ViewSonic VA1703wb Monitor
Computers & Internet Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
