Question about Life Fitness 91Ti Treadmill
Life Fitness Treadmill 91Ti. Came in to work and the machine was running very fast and had an overspeed error. Now on start up the belt runs very fast. Input screen says to pick a workout, but you can't. Also you cannot control the speed or stop the belt without turning the unit off. There are only 313 hours on the unit. I replaced the opto sensor, and I still have the same result.
  • Cindy Aldridge Oct 16, 2013
    There is not a software calibration option when I go through the system menu. I went through all the options: System test, belt/deck test, etc. The belt just runs i cannot stop it our adjust the speed. It is stuck on high speed.
    Top Expert:
  • Life Fitness Master
  • 12,223 Answers
Run the software calibration for easy diagnostic and fix it.
God bless you
Posted on Oct 14, 2013
Testimonial: "There is no software calibration option."
3 Suggested Answers
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
  • 48 Answers
SOURCE: Life Fitness T5i treadmill, stops without warning
hi
try to adjust and clean speed sensor and wheel on the motor
Posted on Nov 25, 2010
Belt keeps slipping on treadmill and belt is all the way back
If you have adjusted the tension on your belt to the max, it is more than likely time to replace your running belt. The running belt naturally stretches over time. I would suggest replacing the belt and flipping your deck. If the deck has already been flipped once, then you would need to replace the deck as well. Life Fitness Treadmill Belt and Deck Replacement Video 95T
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Lifefitness treadmill belt sticks even though wax bag is full
It may not be sticking, but instead slipping on the front roller. You can resolve this by simply tightening the running belt. This adjustment will be done by using the rear roller.
Lifefitness treadmill belt sticks even though wax bag is fulll
alot of times you have to remove the wax spray nozel and clean as the wax hardens over it
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
Treadmill 91ti lifefitness is making high pitch noise as belt starts. Is anything wrong.? Should I use the the treadmill with this nose.
No do not use, until YOU LUBE. This happen because you must do it every 5 hours aprox of use, The machine protect itself the electronic system and shut down.Maybe the deck belt is worn.
2) LUBE the rollers bearing very i
3) test the drive belt, and test too the bearint of main motor and fix it.
God bless you
Nov 19, 2012 | Life Fitness 95Ti Treadmill 95 Ti
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Life fitness treadmill display: transistor error-won't run
Solution
Feb 28, 2009 | Life Fitness Remanufactured Next...
Life Fitness 91Ti Treadmill  Logo
107 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
