Question about Myers Pump QP10-3
Calling pentair pump is working fine, but making very loud noises when the sprinkler system is working.
  • 3,382 Answers
I am assuming it is several years old and has given a lot of good service. It is probably one of two things, it is getting air in the suction line causing it to cavitate or it is wearing out and ready for a rebuild.
Posted on Jun 17, 2014
My pool pump is suddenly making loud noise at times
It sounds like you either have a bad bearing or a broken impeller. This will not get better wioth time. You need to get it repaired.
Sep 02, 2015 | Pentair WHISPERFLO PUMP .75 HP FR EE...
Sprinkler pump makes loud noise when it is running, how to fix?
Typically this sound indicates bearings going out. Usually this means replacing the motor, or may be repairable depending on size and make.
Jan 11, 2013 | Pool & Spa
Whisperflow pump making loud squealing noise
The noise is likely either the seal or a bearing in that order. If you are mechanically capable of working on the pump yourself then you can purchase a seal and gaskets at a pool supply store. If the bearings are bad then the motor needs to be replaced. In some cases a bearing can be replaced but usually it is more work than it is worth.
Aug 09, 2011 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Making loud noise
amigo tengo varios años usando bombas y cuando estas hacen ruidos fuertes a resultado ser los rodamientos o defectos en el inpele
Nov 01, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Need to replace impeler on flotec pump
Contact flotec directly for impeller tollfree 1-800-365-6832
or they may have been acquired by Pentair so try
PENTAIR WATER
STA-RITE INDUSTRIES
200 Tate Street
Union City, TN 36261-024
(800)-800-468-7867
(FAX)-800-390-53
Feb 19, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Pump motor makes loud noise when pump comes on
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out.  There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
Dec 28, 2008 | Pentair 1.0 Hp Whisperflo Pump
Myers Pump QP10-3 Logo
59 people viewed this question
Top Myers Plumbing Experts
kli99gunrunn
bobalix
Gil Shultz
Are you a Myers Plumbing Expert? Answer questions, earn points and help others
