Question about Moultrie Game Spy M-990i
I get occasional whiteout photos during the day. You can see the objects but they are not in color and have a washed out appearance. I sent the camera back and they did some testing and sent it back to me indicating no issues noted. I just put it back out in the woods and pulled the card. I only had 18 pics on it but the last three were the same type scenario as before and they were all taken between 9:30 and 10:00 AM. Have you heard of that before? Any suggestions?
3 Suggested Answers
  • 11967 Answers
SOURCE: We took photos on our
The formats are different among camera brands. They are not usually interchangeable.
Posted on Aug 18, 2010
  • 296 Answers
SOURCE: camera worked great the first
O.K.,I assume you use two SD cards, take out the one in the camera, put a blank one in the camera,and bring the one that was in the camera home to review pics on your PC...unless you have a laptop you carry to the field with you.Either case, you viewed SD card and nothing...switch on side of card pushed forward toward contacts?Always deleted pics using camera's delete function..NEVER DELETE USING PC;NEVER FORMAT USING PC;...
Moultrie says to only use high quality SD's...recommend Sandisk or Lexar...I never had problems with any SD as long as I stay with name brands...I find I have accidently moved write protect switch; deleted before thought from PC...or PC says card needs formatting before use...DON'T..this is just PC not recognizing card's format..try different cards,they do get corrupted...make sure card insertion slot is free of debris...blow it out with contact cleaner/duster,ect....then the M80 has a software upgrade from www.moultriefeeders.com.
Posted on Dec 16, 2011
Looks to hahe convergence problem. 3D look and bowed on top and bottom. I press the flash focus and the + sign appears, but there is no adjustment.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 20, 2010 | Sony KP-51WS500 51" Rear Projection...
Problems printing photos
Are you using HP cartridges with the printer? there are known problems with non hp cartridges in hp printers.
Jul 21, 2008 | Apple HP Officejet G85xi InkJet Printer
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
Color has warped
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Nov 17, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Racheting Noise and not working
could be a bad cam. take off the button on top of the agitator. there should be a cam assembly underneath. they are just little plastic tear drop shaped objects that wear out quickly and need to be replaced occasionally.
Oct 10, 2009 | Kenmore Washing Machines
Bad photo sensor
Canon will repair that problem for free. I'm assuming you mean Canon when you say "Dealer". If not, hope you were not paying money for those previous repairs. Recommend not letting anyone but Canon touch that camera. Please see the following:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=320&modelid=15658&keycode=2112&id=39151
Jul 12, 2009 | Canon PowerShot A650 IS Digital Camera
Convergence toshiba 50a62
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Nov 20, 2008 | Apex Digital GB5108 51" Rear Projection...
Dgs 100
If the pink & white pics are a small percentage of your photos you should probably just live with it. I have 6 cameras in operation for 2 yrs & they have about 10% like this. Great pics otherwise. Probably caused by the angle of the sun or reflection of the flash off a nearby object.
Don
Jan 18, 2008 | Moultrie MFH-DGS-100 Digital Camera
Problem with color quality - Canon PIXMA iP4000
i had this problem... its the ink! Check you are using magenta and NOT "photo magenta", and also that you are using "cyan" and NOT "PHOTO cyan"... basically photo cyan, photo magenta and photo yellow are not designed for the ip4000, if you check the smallprint on the box it does not list the ip4000.
This exact problem happened to me and it was driving me crazy. I think the "photo" versions of the inks are for printers that take two tanks of each colour, and the photo version is used for very subtle colours... so if you are ONLY using these inks, photos will appear washed out, yellow etc
Oct 30, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
White objects appear pink
This sounds like a budding CCD problem that Canon is aware of. Canon is replacing the defective CCD at no charge. Go here for the link and more details on getting a free mailing label: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8044&keycode=2112&id=29819
Dec 17, 2006 | Canon PowerShot A95 Digital Camera
Moultrie Game Spy M-990i Logo
32 people viewed this question
Top Moultrie Video Cameras Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
