Question about Teac Audio Players & Recorders
How do I adjust the speed on a TEAC TS 270S turntable?
4 Suggested Answers
  • 42 Answers
SOURCE: TEAC LP-R400
Yes, both speeds can be adjusted internally, but you will have to take it to a repair shop. It is a very simple adjustment.
Posted on Jan 25, 2009
Grubhead
  • 5484 Answers
SOURCE: teac turntable plays too fast
This sounds like a motor speed control problem. It could be either the motor itself or an electronic fault. So unless you know a bit about electronics and know how to use a soldering iron etc, then the answer to your question is no.
Posted on Oct 24, 2009
  • 11800 Answers
SOURCE: The speed adjuster on my
That selector is basically a small switch that has a blade inside it that slides and makes a contact between some pins: depending on which pins are connected the motor spins faster or slower.
In your case that switch has failed and the contacts are made at random so the motor spins wrongly. To fix it you must replace the switch, a simple electronics job, but one that requires at least a basic experience in electronics and a minimum of tools: a soldering iron, a solder pump and some paste.
If you don't posses all of them you will have to take it to a repair shop - luckily it will be a cheap fix, no more than $50.
Posted on Jul 08, 2011
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
May 15, 2011 | Teac SL-A100 Turntable
My Teac sl-a100 record player sounds like a chipmunk
hi,
somewhere on that player is a switch for 78-45-33 rpm the speed switch look up around by the tone arm above by where the record goes, it may not be on the front. switch it to the correct record you have 45's are small. 78's are medium and 33rpms are the big records..
jm
Apr 30, 2011 | Teac SL-A100 Turntable
The tone arm lifter on my TEAC P-9 turntable is not working right, probably needs adjustment,how do I do this?Have no manual Frank
Hi there! I also have this problem - the tonearm is moving too high and it touches the cover of the turntable. A sa result it isn't workin properly. I have tried to interfere inside the equipment but I didn't manage to solve this problem. Does anybody have such a problem with this turntable. I am searching for a service manual for it. I've searched then net, but with no results. Thanks in advance for any answer. Best, AVint.
Nov 12, 2010 | Teac Audio Players & Recorders
Teac turntable plays too fast
Oct 23, 2009 | Teac GF-650 Turntable
My TEAC P688 is stuck in chipmunk mode for a large record - how do I slow it down?
Sometimes on the base of the turntable (under side) there are two presets one for the 45 speed and one for the 33. They might be hidden under a label or something. You might even have to go inside to find them. Anyway a small flat head screwdriver inserted in it should adjust the speed. You might have to work out which controls 33 speed. And of course if it is below you will have to figure out how to adjust it with a record playing. "Get out and get under!!!!" as they said about cars!
Jun 28, 2009 | Teac P-A688 Turntable
Problems with weights on turntable arm
http://www.turntableneedles.com/FAQs_ep_33.html
found instructions above.
scroll down to
"How do I adjust tracking pressure and anti skate?" under the section of "OTHER"
Feb 14, 2009 | Teac P-988 Turntable
TEAC LP-R400
Jan 06, 2009 | Teac GF-188 Turntable
Turntable not turning to play record............. power on............ please help my email address - diatmesa@aol.com
This could be many things like the following>
If its a direct drive turntable the motor could be "blown",
or motor electonic speed controller burnt out.
If its a belt drive turntable then the belt could be broken
or stretched and is slipping, or the belt can have dropped of a drive pullety.
Also there are speed control mechanisms to adjust the final speed of the
turntable to the recorded speed of the record like 331/3rpm, 45rpm 75rpm
These speed reducing mechanisims can slip and cause the turntable not to turn..
There are also other mechanical bits that slide and push against each other,
and these can get sticky and the friction increases so much that the power
from the motor drive causes the belts to slip, so you need to identify if a
friction problem exists as well..
If you are carefull you can look your self and find out which one of the above it is.
Be warned there are lethal voltages inside the turntable which can kill you....
so please dont have the power on when making any inspection or adjustments.
Cheers From YUBEUT..
Jul 22, 2008 | Teac GF-350 CD Shelf System
Teac P-988 Everything sounds slow/warped
not passing the "wow and flutter" specs, eh?
The most common cause of this is a loose or defective belt. An inferior belt will have varying thicknesses along it's length. When it hits a skinny part, it will slow slightly. When it hits the thick part, it will speed slightly. Overall effect is that the record sounds warped.
needledoctor.com has got some good stuff.
Jun 12, 2008 | Teac P-988 Turntable
93 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
