Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
I have a mini 49 atv with no power, I've replaced the carb and the spark plug but the problem persists. I also checked the clutch and there's still plenty left. There is a valve on the exhaust like a single reed valve that i don"t know what it is but looks to be in working condition. Any idea what the valve is or why i have no power?
  • 186 Answers
Do you have spark from the spark plug?we can go from there
Posted on Nov 03, 2013
How do I fix my 49cc 2 stroke pocket quad it has
If you have replaced the spark plug then the possibilities are the ignition coil is weak or the starter mechanism is faulty.
See this site for details of parts.
Mini Atv Quad Parts 47cc 49cc Stock Replacement
Sep 15, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Got spark got gas want fire at all
chances are the carb is not set properly. turn the screw on the carb all the way in then back it out 1 1/4 turns. as a trick you can spray WD40 in the carb to start it too. if you can get Either, that works best. you may need to adjust the screw to get it to run at peak performance. adjust it in 1/4 turn increments.
Apr 08, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
1993 yamaha timberwolf will not start
Do you have spark? easy test is to pull a plug wire, hold it close to metal with a stick or other non conductor. DON'T USE A SCREWDRIVER or other metal object. IF you have spark then its a fuel problem, check the tank, remove the fuel line into the carb, getting fuel? If all else fails take your Yamaha to the local dealer for correct repair
Mar 29, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
I pull start my 49 cc pocket bike and it starts. I lift the back tire off the ground and give some gas its fine. but when i sit on it and give it gas it dies out?
You most likely have oil spilled on the clutch. OR, the carb needs to be opened by 1/4 of a turn on the set screw on the carb.
Aug 21, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
My bike wont start I replaced spark plug
most likely carb setting. Try turning the carb set screw all the way in and back out 1 1/4 of a turn. then adjust by 1/4 of a turn to fine tune it.
Aug 05, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
Got spark, got compresson, good fuel but still cant get it to start??
Hi, Try taking out the spark plug and dripping a little fuel down the cylinder. Then, replace the plug and give it a try. If there is a spark the engine has no choice but to start. From here, you can determine that it's a fuel delivery problem and the carb and fuel filter need to be inspected.
Nov 17, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
What size/type of spark plug is in the 47cc mini pocket rocket
Check the owners manual, a lot of pocket bikes have different size spark plugs.
Jul 15, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
