Question about Runco Office Equipment & Supplies
Rs900 need pass code to access service screen
Don't know my password
On the Gmail sign-in screen, click the "Can't access your account?" link.
Feb 12, 2014 | Google Gmail
Get pass lock screen forgot code
use your google play email to get access back into your phone. If this doesn't work call your customer care or take it to the stores technician.
Jan 07, 2014 | Kyocera Cell Phones
I can't get in my controll system it asks for a hdd pass code
access start up options restart and repeatedly press f2 till the screen comes up
Feb 16, 2012 | Acer E625-5776 (LX.N290Y.092) PC Notebook
My laptop is dell inspiron 1545 showing a white screen saying (yhis computer system,#JXJG9H1_595B, is protected by a pasword autentication system . you cannot access the data on this computer without the...
Call Dell if it is still under warranty. Once in a while (Rare) the hard drive will suddenly think its password protected this can be caused by a glitch in the system board bios or the hard drive it self.
Dell with the service tag and service code can give you a password to unlock it. Warning If this fails the drive will need to be replaced. As a tech of 12 years I have seen this only one time. The data was not recoverable because the pass-code didn't work.
Aug 30, 2011 | Computers & Internet
I have a 32" tv... I must have press a button... bcuz now my tv showing blue screen with a small picture in red of a key... can u plz help me how to remove this and get my regular cable tv back on...
Hi msvkam
To answer your question;
You probably have the parental lock on,
Here`s the procedure and factory default code to unlock it:
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the .Menu. key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight .Pass Code,. then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case you forget your new pass code.
Hope this help,
Cheers
Jun 29, 2010 | Apex Digital AT2702 27" TV
How can i unlock my message,i cant gain access to my messages
Usually each service provider has a procedure to access messages. If it is the first time, usually you will need to set up your phone/messages with a pass code. Otherwise, if you forgot your pass code you will need to reset it by calling customer support. Some service providers allow to do this by accessing your account online.
I hope this helps!
May 21, 2010 | Sony Ericsson P1i
I lock my cell phone and forgot the code how do i reset it the phone is a i 465
Unlock Code is a manual hard-lock on handsets which requires the correct pass code to allow access to the phone's functions.
Occasionally, people purchase used handsets. Previous owners may have locked the handset and are unreachable to get the new pass code
To unlock the phone using the factory default pass code, perform the following:
1. Confirm the phone shows, Enter Unlock Code.
2. Press the MENU button. The screen will show, Enter Security. Try both.
3. Enter last 4 of PTN, unless you have changed the lock code, and press OK. OR
Enter six zero's (000000) and press OK.
*If successful, the screen will display, Phone Unlocked.
*If unsuccessful, the screen will display "Security code is incorrect please try again."
If the you don't know the code, You will need to contact Motorola to have it re-flashed, which may incur a service charge from Motorola.
4. You now has access to use the phone’s functions.
5. Do not change the Unlock Code.
Oct 10, 2009 | Motorola Mobility Clutch i465 Cell Phone
I forgot my pass word fro my sidekick3
yes, you can.
This tip unlocks the 3 digit security lock.
1. at the same time hold the menu button (top left) and the jump button (bottom left)
2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
4. The phone will reset and clear/unlock the security code
Known to work on the Sidekick 3
Nov 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Unlock apex tv model # AT2702
try this manual;
[PDF] AT M C T
On the remote try pressing the ( F ) button and the mute button at the same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Pass Code Menu
functions of the TV set. Pressing the “Menu” key when Pass Code
the down arrow key to highlight “Pass Code,” then enter the new Pass
2. The factory defaults have TV-MA and MPAA-X ratings blocked . Hope this may help you
DON'T FORGET TO RATE:
Apr 17, 2008 | Apex Digital AT2702 27" TV
43 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
