Fabric softener won't work
Hi my fabric softener dispencer won't work i have rinsed it out and it still won't work what can i do
    Scholar:
  • 79 Answers
G155
You have to do it manually. See below from manual:
Liquid Fabric Softener (Manually add during rinse cycle)
1. Turn OPTIONS knob to FABRIC SOFTENER
2. Measure liquid fabric softener carefully, following instructions on the bottle, and add during the rinse cycle.
OPTIONS (on some models)
Set this option when planning to manually add fabric softener during the rinse cycle or when you use extra detergent or bleach to clean hazily soiled items. It provides an enhanced rinse.
Sep 09, 2012 | Hotpoint Washing Machines
Fabric softener does not dispence
Just fixed the fabric softner dispenser for my wife, so I wrote a tip about it...
Fridgidaire Washing Machine Fabric Softner not going into washer
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 24, 2010 | Frigidaire Affinity ATF7000E Front Load...
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water softener goes in at wash cycle rather than rinse cycle
if it has to go in the rinse,,this means you have to put it in the fabric softner compartment of the dispencer,,,also do not fill pass mark fill line in dispencer or it will sphion down by itself before time..onthejob
Jan 25, 2009 | Kenmore Elite 45986 Front Load Washer
Remove the fabric softener compartment for cleaning
open up and on the left side toward the back you see a little tab push it down pull out the dispencer
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Fabric softener dispencer
The inlet for the softener may be plugged. Try a toothbrush to clean the area.
Jan 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bleach and Fabric softener not dispencing
One thing that I did was to clean out the filters on the inlet hoses.  This increased the water pressure to the machine and improved the situation.  I am still having trouble with the bleach dispenser.
Oct 08, 2007 | Maytag Neptune MAH6500A Front Load Washer
Problems with fabric softener
check the water solenoid for open circuit, this is the water valve that supplies water to the compartment
Sep 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
306 people viewed this question
Top Washing Machines Experts
