Question about Staples Executive EPS711X Shredder
Executive Machines EPS-1200X Shredder has power but papers are stuck and there is no sound from motor
  • Sandor Batyi
    Sandor Batyi Oct 16, 2013
    Used needle-nose pliers to remove chunks of stuck paper from between the teeth... motor couldn't move, not even make a sound. Now it is working again.
  • 221 Answers
You will need to clear the jammed paper using tweezers from between the rollers. Make sure the sensor arm in the middle of feed opening is not stuck and moves up and down freely. If not you will need to give it a good soak with lubricant to allow any stuck paper to soften and loosen. Once cleaning procedure done unit will be good as new
Posted on Nov 04, 2013
Cleaning a shredder that has sticky paper stuck to the cutters. A EPS-611x.
FIRST MAKE SURE THAT YOU HAVE REMOVED POWER
UNPLUG IT
Using pick remove the paper that is stuck to the cutters,
also you could try shredder oil to assist after you have removed
a majority of the sticky paper...Take a piece of paper fold it
in half, apply a bead of shredder oil the length of the folded paper
Run it through the shredder like you would a plain piece of paper keeping it folded
Sep 05, 2017 | The Office Equipment & Supplies
Repair of a Staples shredder EPS-1200X
Unplug it from the wall unit. Check to see if there is any tiny piece of paper stuck in the machine, if there is you can use
tweezers to pull the small pieces out. Then you can put it in reverse and let any paper that my be stuck in it come out.
Make sure that there is no paper caught in the teeth at all or it still might not work.
Jun 11, 2017 | Cars & Trucks
Executive paper shredder eps-711x wont shut off
around the middle of the cutters there is a small lever that operates a microswitch
that level gets jammed in the on position from paper scraps and keeps the machine running
remove that paper bit and the machine will switch off
May 23, 2016 | Shredder Office Equipment & Supplies
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
Does not auto shut-off anymore?
Automatic feed switch jamed with paper. reverse and forward several times may help. Otherwise turn it over and pull paper out of the bottoms to clear the switch jam.
Apr 06, 2015 | Cross Executive EPS-1501X Shredder
How do I oil my executive machines eps-1501x paper shredder
Oil the shredder blades. Refer to this article: http://lifehacker.com/5875771/oil-your-paper-shredder-with-canola-oil-to-keep-it-running-in-top-shape
Mar 02, 2015 | Shredder Office Equipment & Supplies
My EPS-1501X has photo sensors that stops the motor from running when the paper reaches a certain height. How does this regulate the overflow?
From what I have seen on mine, there are three sensors: one to detect if the door is open, one to detect when the unit is full, and one to detect when material is fed.
As for mine, the unit would not start when it was fed. Once I opened it, I saw the photo sensor was missing a screw. I realigned the bezels and added the screw. However, once I reassembled it, the unit still had the same issue.
Now, I suspect that it is the control board. I have no time to get into that, but it does not look too difficult.
I searched the internet for support, but there seems to be no company presence available. So, I think I am stuck manually triggering and stopping the motor.
It is an amazing shredder otherwise and I would not even consider replacing it. At least, not until the motor fails.
From what I have seen inside, I doubt that will be anytime soon...
Jan 03, 2014 | Cross Executive EPS-1501X Shredder
Executive EPS-1501 X Shredder automatic sensor doesn't turn off
Do not use any aerosol based or petroleum based products in your shredder as this could cause a fire. I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Nov 06, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Staples Executive EPS711X Shredder Logo
1,031 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
