Question about Sharp 27U-S50 27" TV
Closed caption is not clearing the text from screen.
Text is coming up on screen on all free to air channels. How do I get rid of it? Thank you
Hello, Margaret -
By text on the TV screen, do you mean closed captioning text? Is the text the same wording as what is being heard? If so, that is closed captioning (for the hearing disabled.)
The button for closed captioning on your TV remote was probably pressed inadvertantly. Locate the closed captioning button on the remote, and while the TV is on, press it to see if the text disappears.
Dec 21, 2017 | Televison & Video
Captation on TV screen can't get it off
Hello
To choose a Captions or Text setting, press "TV/CAP/TEXT". Each press brigs up a different settings. your closed-caption?text options are:
CAPTION CH1, CAPTION CH2, TEXT CH1 and TEXT CH2.
Note: Not all programmes carry closed captions or Text. If captions are available, they will probably appear on 'CAPTION CH1'
Press "TV/CAPTION/TEXT' button on the remote control repeatedly to On and Off the caption function.
Dec 29, 2011 | Zenith TVBR1322 13 in. Combo
Black box blocks out lower half of television screen
Check your closed-caption settings. If you have captions on and set to "text" mode, this can happen. The TV blanks out the area on the screen where the text should go, but there's nothing to display. Turn off captions or set for regular caption mode, and that should clear up the mysterious box.
Jun 02, 2011 | Jensen Q2749J 27" TV
Does the toshiba 27a44 have closed captioning?
Hello
You have two options with closed caption feature.
Captions of Text
A caption is a printed version of a dialogue narration and/or sound effects of a programme. Text is information not related to the programme that appears on half of the TV screen when available.
To view Caption or Text
[1] Select the desired programme. Closed captioned programme are usually marked in your local TV listing as "CC"
[2] Press CAPTION/TEXT repeatedly to select caption or text mode.
[3] Press 1/2 to select the caption or text channel.
[4] To turn to off the closed caption feature, press CAP/TEXT repeatedly until captions or text no longer display 0n-screen.
Ok.
Nov 15, 2010 | Toshiba 27A44 27" TV
Square Black marquis takes up the screen seconds after channel changes. Can't make it go away.
Check your closed-caption settings. You will probably find the TV is set for "text" mode right now. There's usually a single button (may be marked "CC" or "Caption") on the remote control to choose the setting. It's easy to bump the button accidentally and set captions without realizing it. When set for text, the TV blacks out the area where the text would go if there was any. Turning captions to "off" will clear up the mystery.
Oct 28, 2010 | JVC AV-27530 27" TV
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
After a power flicker our TV Has a large black square in the middle of the screen. Problem is that the commercials are AOK but as soon as regular programming resumes....black box. HELP!!!PLEASE!!!
You have the closed-captioning turned on and set to "text" mode. It probably got set this way because of the flicker. Use the remote (or front panel menu buttons if this set has them) to get into the closed-caption settings. Turn captioning off and the box will be gone.
In case you're curious, the reason this happens is that the set clears the screen where the text will be displayed, but there's no text. On programs or channels without captioning the box disappears.
Jan 27, 2010 | Televison & Video
Cannot get closed caption
To view captions or text:
1. Select the desired program. Closed captioned programs are
usually marked in your local TV listing as “CC.”
2. Press CAP/TEXT on the remote repeatedly to select caption or text mode.
3. Press 1/2 on remote to select the caption or text channel.
4. To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen. I hope this helps. Thanks for using Fixya. Good luck
Nov 04, 2009 | Toshiba 20AF45 20" TV
There is a big black box blocking the screen and it will not come off. how do i solve this problem without a original remote.
Check your TV's closed-caption settings. You'll likely find it's set for TEXT mode. Turn off captions or set for CC1 or CAPTION 1 if you want to use the captions. Your trouble is due to the set blanking out a block on the screen where the text should go, but there isn't any text to display. Most TV remotes have a single button for caption control, so it's easy to get into text mode without knowing it. Then on channels where captions are being broadcast you'll see the box. On other channels or programs you don't see it.
Please take a moment to give this solution a fixya rating if it clears up your trouble, and thanks for asking here!
Mar 17, 2009 | Sanyo DS31590 31" TV
Black translusent rectangle (band) lower mid screen
You have the closed captioning turned on and it's set to "text" mode. On channels where closed captioning is being broadcast the set is clearing the screen for the text which isn't there. That's why you don't see it all the time or on every channel. Just use the remote or front panel buttons to go to the caption settings and turn it off.
Dec 14, 2008 | Vizio L32 32 in. LCD HDTV
Sharp 27U-S50 27" TV Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
