Harman kardon avr 139
No sound hdmi
robotek
  • 1512 Answers
SOURCE: How to I reset my
Hi odysy
I got this from the manual page 43.
Resetting the Remote Memory
As you add components to your home-theater
system, occasionally you may wish to totally
reprogram the remote control without the confusion
of any commands, macros or ”Punch-
Through“ programming that you may have done.
To do this, it is possible to reset the remote to the
original factory defaults and command codes by
following these steps. Note, however, that once
the remote is reset, all commands or codes that
you have entered will be erased and will need to
be re-entered:
1. Press any of the Input Selector buttons 4
and the ”O“ button Hat the same time until
the Program/SPL Indicator 2begins to flash
amber.
2. Press the ”3“ button Hthree times.
3. The red LED under the Input Selector4
will go out and the Program/SPL Indicator
2will stop flashing and turn green.
4. The Program/SPL Indicator 2will remain
green until the remote is reset. Note that this may
take a while, depending on how many commands
are in the memory and need to be erased.
5. When the Program/SPL Indicator 2goes
out, the remote has been reset to the factory settings.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jun 29, 2008
SOURCE: Harman Kardon AVR 40 no sound
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
Posted on Sep 06, 2008
smarthome2
  • 1114 Answers
SOURCE: Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
Posted on Jul 01, 2009
  • 256 Answers
SOURCE: how to connect a microphone in an harman kardon
The only way is to get yourself a separate karaoke mixer that you can connect to your receiver, or get yourself a small two channel disco mixer
Posted on Aug 03, 2009
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
Connect pc
To connect your PC or Laptop to your Harman Kardon AVR 2600 you need to connect the HDMI cable output of your graphics card to one of the 4 HDMI inputs on the AVR 2600 receiver. The HDMI connector on the AVR 2600 labeled "HDMI Monitor" is on output and cannot be used as in input.
You need to select the corresponding input from the front of the AVR 2600 or using the remote. Next you need to make sure your have the HDMI output port selected on hour graphics card. This will probably not apply to your PC, but may require some settings from the function keys on your Laptop.
Note that you will probably need to also connect audio from your PC to your receiver as well. I would recommend you use HDMI cable with ver1.4 specification so that you have the best chance of getting audio over the HDMI. If you only get video, then run separate Toslink (optical) or RCA cables to get the audio to the system from the PC.
Jan 12, 2014 | Harman Kardon AVR 2600
HARMAN KARDON AVR 142 and APPLE TV
you must contact to the supplier manufacter via ONLINE chat and get support or call to the toll free for the consultation.
God bless you
Nov 25, 2013 | Harman Kardon Audio Players & Recorders
Harman/Kardon AVR 3650 3D A/V Receiver
Make sure TV's HDMI port is working if it is working check it with a new HDMI cable changing the HDMI cable will fix the problem
Dec 15, 2017 | Harmon Kardon Harman/Kardon AVR 3650 3D...
Harman kardon 2650 auxiliary ports 2,3,4doesn't work
if you are talking about the hdmi ports, 3 are ins and one is out, but I use the hdmi from player direct to tv, and use coax or optical connection to my receiver for the audio
Mar 23, 2013 | Harmon Kardon Harman Kardon AVR 2650 7.1...
No input to tv
Hi, during the last 3 years, my Harman Kardon AVR3600 has worked perfectly, but suddenly i don't know why does my unit only provide sound, and no video.
That I can do, and reset the unit, change the HDMI cable, etc... but still no video. Tkhs
Mar 19, 2013 | Harman Kardon AVR 3600
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Can I conect harman Kardon avr 230 to apple tv
Dec 08, 2009 | Harman Kardon AVR 230 Receiver
Jun 27, 2009 | Harman Kardon AVR 235 Receiver
85 people viewed this question
 Grubhead
Grubhead
