Question about Garden
I need the garden house coupling for pressure washer model VPW45H!
    New Friend:
  • 47 Answers
Hi, it should be a 3/4 bsp male fitting. readily available from garden centres, home depot .etc
Posted on Oct 16, 2013
2 Suggested Answers
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
Water leak where the gun hose connects to the washer causing very low pressure 2200 psi model 020245
Simple fix, just disconnect house end from washer, buy a new rubber washer o ring, like what is used for garden hoses. Put back on make sure it is tight. If still leaks, then need to replace connection end fitting on preside washer, can get those at almost any hardware store, use plumbers tape on threads when putting new fitting on machine, then connect house and back to those honey do list :)
Jun 08, 2011 | Garden
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
The pressure washer motor is running and water is flowing through but there is little to no pressure on the water coming out
pour liquid TSP into the fresh water port (where the garden hose connects) and let it sit there for a couple of days.
This will clean all the calcium and lime deposits within the pump.
This is how I fixed my pressure problem.Hope it works for you.
Aug 28, 2010 | Honda Pressure Washer PSI 3000
I have a tpw 2200 pressure washer that has lost high pressure. i have low pressure but not high pressure.\r\n The machine i have is a titan tpw 2200 if some body can tell me what is wrong please help. ...
Pour a large amount of liquid TSP into the fresh water inlet where the garden hose connects and let is sit for a couple of days.
Aug 04, 2010 | Garden
No pressure HOSE IS BIG ENOUGH,NO KINKS, FILTER IS CLEAN. TOOK THE PUMP APART AND CHECKED ALL THE CHECKS, THEY WERE ALL OK.WHAT ELSE CAN I LOOK FOR? THE PUMP IS A KARCHER-MODEL G 1800 LB Thanks, Art
Brother Art,
Try this trick; it always works for me. Assemble the garden hose to the washer, install the HP hose, turn on the water. Now, make sure that there is no air trapped in the garden hose. Manipulate so as to direct any air trapped in the line to the washer. Connect the gun and continue to allow water to "free flow" for several minutes. Now, work the trigger, allowing the unit to rise to "house pressure, and then pull the trigger, dropping the pressure suddenly. This displaces any air hidden in the system. Do this several times, and start the washer up. If this doesn't get you up to pressure, repeat the above on an abbreviated scale, and hold the trigger on the gun down while you start the washer. This should do it.
Regards, --W/D--
Aug 08, 2009 | Karcher Garden
Pull start locked up
take the housing off and see if you can free it up if not you will have to take it apart and rewind
Jun 20, 2009 | Briggs and Stratton 020275 Elite Series...
Husky power washer no presure?
Found an easy solution to my problem. Was dumping pressure out the bottom when I pushed the trigger. Turned out the line my hose reeler that my hose was running off of was kinked. Only partial pressure was going from the house hose to the pressure washer. I attached my house directly into the house, bypassing the hose reeler, and it worked fine. Apparently, you need a certain amount of pressure going into the washer for it to work.
Mar 20, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
