Question about Maytag MSD2732GR Side by Side Refrigerator
Refrigerator door does not close by itself. - Maytag MSD2732GR Side by Side Refrigerator
    Problem Solver:
  • 10 Answers
Lubricate the hinges? The top hinges may be under the plastic covers that snap on the top.
Posted on Oct 19, 2013
Refrigerator ice dispenser flap opens and closes itself
You need to replace the PCB located in the back of the refrigerator. Took me about 20 minutes after I got the part. Then you will have to program the code back into it. Costly but rather easy.
Feb 10, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
I have top freezer LG refrigerator (I have it for a week, so it's a brand new). When I close refrigerator door the freezers door bounces opens and closes). Hoe to fix this problem?
When you close the door, the air pushed in by the door has to do somewhere, so it may momentarily pop the other door. As long as it closes right away by itself, no problem.
Apr 19, 2011 | LG LRTBC1825T Top Freezer Refrigerator
My freezer door pops open everytime i shut my refrigerator door
Good day,
First, make sure the gasket including the bottom is clean, as well as the mating surface of the machine itself.
The machine itself should be checked for being level. Side to side, if it's a top freezer model, the hinge side cannot be lower than the other side.
As well, front to back it should be leveled but with a slight tilt to the rear to assist in closing.
If none of this helps, then the magnets in the gasket itself have gotten weak and the gasket needs replaced.
Notes: Heavier items keeped in the freezer door will help to a degree. Closing the door slower as well.
The reason this happens, is that with the main door open, then closed, a large volume of air is forced into the fresh food compartment. There are vents that are open between the freezer section and fresh food compartment. This large volume of air when closing the main door is compressed into a smaller area, causing the problem.
Feb 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool side by side refrigerator door not closing by itself. Ideas?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door itself...you see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Jun 05, 2009 | Refrigerators
Kitchenaid refrigerator side by side, refrigerator door will not close on its on like it use to. Model #KSRS25qDWH01 bought in 1996. If we give it a push it closes fine. But it use to close nearly b
order a cam and stop for the affected door. it is on the top of the hinge and the bottom of the door, you'll see the two pieces if you look where the door contacts the hinge, call a dealer for the correct part numbers.
May 04, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refrig door gasket does not prevent gap when door is closed
Lift up the gasket and look for screws securing the gasket to the door.
Loosen all of these screws a few turns and twist the door in the direction needed to seal.
Hold the door in this position as you tighten the screws.
This can be tricky and sometimes requires multiple efforts.
Apr 03, 2009 | Haier HSL06WNAWW Compact Refrigerator
Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
Refrigerator Door
hi thanks for the question i would first try to raise the front of fridfe to the point where door closes by itself if left open look at the liner where the shelves are if the shelf is all cracked that could cause this problem thanks the appliance doc
Sep 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MSD2732GR Side by Side Refrigerator Logo
54 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
