Question about Whirlpool Dryers
Estate dryer model EED44COWQO won't heat. stats and elements are good
aborcass
  • 2651 Answers
SOURCE: kenmore dryer model 65512
check the continuity on the thermal fuse located on the back wall small white thermostat perhaps 1.5 inches by 1/2 inch, and if no tcheck the thermo on to p and next to hte heater hte should all have continuity. if not replace them as ness.
Posted on Mar 25, 2008
SOURCE: WHERE DO I FIND THE HEATING ELEMENT ON A ESTATE DRYER
i have a estate dryer it blows hot air and drum turns but does not dry the clothes so it takes 3-4 rounds to dry the clothes what cold be the promblem
Posted on Mar 17, 2009
mgprice
  • 744 Answers
SOURCE: Dryer will not heat
Hello there are a few other things you can check, one would be the thermal cutout, looks like this 2385c5d.jpg also check the centrifigal swith which is built into the motor, you can check this by bypassing the 2 large (normally red) wires to the motor, if the heater works then you are going to have to replace the motor since the switch is built into the motor. Also and I am not sure if you checked it but test the Hilimit thermostat for condinuity, if it's bad replace it. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike
Posted on Jul 15, 2009
heatman101
  • 43501 Answers
SOURCE: REPLACING HEATING ELEMENT IN ELECTRIC ESTATE WHIRLPOOL DRYER
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 27, 2010
  • 2468 Answers
SOURCE: Maytag dryer heating element won't come on
you should have a nominal 240 volts between the 2 heating element connections
Posted on Feb 08, 2012
What is the part number for the heating element in a whirlpool estate dryer 2406026-fm54?
There are different ones, so you need to disassemble enough to get a good look at it, then click on this link to repairclinic.com
http://www.repairclinic.com/Shop-For-Parts/a8b5c42-x776869726c706f6f6c2032343036303236666d3534/Whirlpool-2406026Fm54-Whirlpool-Dryer-Heating-Element-Parts
and order it. . . They also have movies here giving you some direction on replacing your element . . You'll save a good bit of money . .
Jul 20, 2014 | Estate EED4300TQ Electric Dryer
Replaced the heating element of our Frigidaire Gallery Dryer, model # GLER331AS2 and still not heating. What next?
The next thing to check is going to be the HIGH LIMIT THERMOSTAT it fits onto the outside of that round housing where the element is.To check it DISCONNECT POWER TO DRYER open up the dryer as you did to replace the heat element and remove the 2 wires from it,use a multimeter set a low ohms rating and check thermostat for continuty with ZERO ohms resistiance on the 2 terminals on that t-stat. IF that t-stat checks good, next check the cycling t-stat in same manner. IT's going to be in the housing where the blower wheel goes and not on the round housing. If that too checks to be good replace timer
Good luck,i hope i have been able to help you fix your dryer,
GENE
Aug 16, 2011 | Dryers
Put new thermal limiting switch, thermal fuse and heating element in my whirlpool estate elec. dryer. it will not get hot still is there something i,m missing?
their are several possibilities
1) check breaker and or fuse to be supplying 240 volts to the dryer,even though the breaker seems to be on a internal burned out breaker will appear to be set but 240 vac not at dryer
2) check were the cord connects to back of dryer that one on the legs hasnt burnt and only 120 vac to dryer instead or required 240 vac
3)depending on your model i dont know if you have a timer or computer control but it isn't sending power to the element
4) the motor switch could be defective, all dryers are required by law to have a built in safety that assures the dryer will not heat when it isn't running to do that all dryers have a switch built into the motor that will only send power to the element once its running
5) in addation to the high limit t-stat and thermal fuse all dryers (depending on model) have a cycling t-stat or thermistor that controls the normal operating temp (the high limit and thermal fuse only come in to play when a dryer overheats) that could be defective
Jul 22, 2011 | Whirlpool Washing Machines
Replaced heating element and it is still not drying clothes what else could it be
thermal fuse:
http://www.applianceaid.com/pictools/thermalfuse&stat.JPG
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Feb 18, 2011 | Estate EED4300TQ Electric Dryer
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryer lost heat according to different cycles
the model number you have is for a gas dryer if this is an electric dryer then you can access the heating element by removing the back cover this has a small element you can remove it by taking the 1/4 inch screws from the sides of the element there could be two screws or just one remove the screws and pull the element out you con then visually inspect it but the best way is to ohm it out with a meter but your problem sounds more like a timer
Sep 18, 2009 | Estate TEDX640JQ Electric Dryer
Nov 05, 2008 | Kenmore 63942 Dryer
Dryers Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
