Question about Bose QC15 Headphones
Battery leaked and headphones stopped working
Can the battery in my headphones be replaced?
All batteries can be replaced if you can get to them, which is often the problem. If you can get the serial number off the battery, these people are good. Battery Buyer Batterybuyer com
Nov 10, 2015 | Jam Transit Wireless Headphones White...
Why does the myzone headset we purchased not work, as the red light will not turn on?
Not sure how old this unit is but you need to check your battery connections for crud.
If the battery's have been leaking or the terminals are corroded it will not power up. I beleave that unit takes rechargeable batterys.
May 15, 2014 | Lands Phones
Bose quietcomfort 15 right headphone stopped working
My guess is that the flimsy wire connection inside broke. I have worked on Bose earphones that do not even have any strain relief provisions.
Jun 25, 2017 | Bose QuietComfort 15 Headphones
I have HDR65/RS65 Sennheiser wireless headphones. I disconnected them to move stuff around, then re-connected them. Now all I get is a 2 second cycle consisting of: 1 second of static that builds in...
Try connecting them to an MP3 player or connect wired headphones to the same source to make sure the sound source is working correctly. If that works, verify the voltage on the batteries is 2.4 volts after charging. Mine stopped charging fully and the headphones wouldn't work at all, but when I connected a couple of AAA batteries to it in series, it worked great.
Nov 15, 2010 | Sennheiser RS 65 Consumer Headphones
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
Intermittent Crackling noise in the right headphone
Hello Rachel, I use my QC3 for 2.5 years Mon-Fri for 3 hours a day. I have the same problem when battery is weak and/or it is cold outside. The cracking nose stops for me if battery fully charged. This is known problem andBose put it in the manual.
Vlad
Aug 28, 2008 | Bose QuietComfort 3 Acoustic Noise...
Noise concelling head hpones
Same here, my QC 3's stopped working, bought a new battery and nothing happened. Called Bose 1-877-210-3782 followed the prompts for "english" and "headphones". My QC 3's are 3 years old and out of warranty. Bose agreed to replace the headphones for $75 with free shipping. Better than paying a few hundred. Replacement set will have 1 year warranty.
Apr 27, 2008 | Bose QuietComfort 3 Acoustic Noise...
Not charging
Did you try charging the batteries with another charger?
Mar 03, 2008 | Sennheiser RS 130 Consumer Headphones
Bose QuietComfort2 Acoustic Noise Cancelling Headphones not working
same thing has happend to me, sometimes when im playing around with it i get about 2 hours use before it turns off again. do you recon its worth sending it off to bose for repair?
Oct 05, 2007 | Apple Bose QuietComfort 2 Acoustic Noise...
RCA wireless headphones
solution: the directions state: if the TV volume is not tuned to at least 50 percent or more, the headphones will automatically shut themselves off after 4 minutes to limit electromagnetic waves in the room.
it's a simple solution. simply turn up the volume if the headphones stop working. i know, it happened to me as well--before i read that part of the instructions. take care.
Jul 08, 2007 | RCA WHP141 Consumer Headphones
Bose QC15 Headphones Logo
29 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
