Question about Maytag MTW5900TW Top Load Washer
What is Water capacity of Maytag MTW5900TWO washer
2 Suggested Answers
some1cares_m
  • 5323 Answers
SOURCE: Maytag oversize capacity plus washer wont stop filling with water even when I turn it off and un plug it
Ah thats usually a sign of a bad water inlet valve not to costly and not to difficult to repair somes a bad water pressure switch will also cause an overfill however when power is off that will stop the overflow so we know its ur inlet valve
Posted on Mar 29, 2015
Tub capacity of maytag performa
It holds 3.9 cu feet. According to Maytag "This 3.9 cu. ft. capacity high-efficiency washer also features the MaxExtractâ„¢ option, which spins clothes at up to 1,300 RPM and means less time doing laundry. You get all that and still use 79 percent less water and 76 percent less energy". A cubic foot is the volume of a cube whose sides are all 1 foot long.
Feb 13, 2015 | Maytag Performa LAT2500A
I HAVE A MAYTAG PERFORMA WASHER MODEL#pav3240. the washer continues to fill during rinse cycle and overflows the top. If i turn to spin cycle water drains out and machine goes through cycles. it seems like...
Clean out the water-level switch air dome tube AND the the connection to the tub where the tube connects. It may well be full of gunk and not allowing the water level switch to react quickly enough.
Jun 06, 2017 | Maytag Washing Machines
Maytag oversize capacity washer just finished filling up the tub with water. Then it had a burning rubber smell. I shut it off and on a bunch of times and there isn't even any sound. (like the mot
You need to observe and check after disconnecting the power , touch the motor, the element area or the control panel or the valves/pump.
If you notice any heat on these , it can be the culprit.
You can proceed to remove the suspected part to discover what was the reason for the burning rubber smell.
Click this link: Element
Jan 25, 2013 | Maytag 3.3 cu. ft. Oversize Capacity Plus...
I have Maytag LS7800 stackables and am happy with the capacity. I am purchasing side by side machines. What is the capacity of the LS7800?
The washer is leaking. Whenever it starts filling water. I checked the hoses they are all fine. It seems to me it's leaking from behind the drum where the water comes in. I couldn't see behind the drum, should I and can I take the top off and see if there is a clip on those hoses coming in
May 28, 2010 | Maytag Washing Machines
My top load washer smells like moldy, nasty water
use some vinagar let wash
i heard deluted CLR works too, but delute it really good
Apr 18, 2010 | Maytag HAV2557 Top Load Washer
What is the vertical pumping capacity for a Maytag Neptune washer
I believe it can be done,but I dont think it is recommended by the manufacturer. if you are in a basement and that is your only option, the only suggestion I would have is to build a platform for the waher and dryer to sit on . It would have to be very sturdy. Maytag recommends that you install a wash tub or something of the sort and install a sump pump to pump the water into the drain.
Dec 17, 2009 | Washing Machines
Maytag MTW5900TW Top Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
