Question about Whirlpool Kitchen Ranges
I have a Whirlpool gas range model#SF395LEEQ. The oven doesn't work. When I press either bake or broil on the control pad and then start, it turns itself off. The clock works, the burners work, and the oven light works, but nothing else works on the control pad. If this means a costly repair I would just replace the range. Please advise.
SOURCE: Amana ARG7300w oven inop
It has a bad oven igniter.
Posted on Aug 27, 2007
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
docjohn174
  • 943 Answers
SOURCE: Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Posted on Sep 28, 2008
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
vijaydangwal
  • 137 Answers
SOURCE: My gas range's oven piezo-electric igniter is not working.
it must be a problem of spark distribution try to remove the spark plug from your piezo electric igniter and clean it throughly it must work otherwise it will have to be replaced
Posted on Feb 25, 2010
Whirlpool range/oven. The display shows "door" controls do not respond
maybe press and hold the bake and broil pads at the same time and hold for 3-5 seconds should show (sf) then press clean pad the display will then show (loc off)lock-out off then press start pad can only be set when oven is not in use JUst a guess but seems to be locked on ??
Nov 26, 2014 | Whirlpool Kitchen Ranges
Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Mar 19, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool Gas Range Model: WFG361LVB Hi I just got this gas oven about a month ago and the top burners work, broil works and bake seemed to work once or twice where i would see the temperature rise and...
Remove power. Go to the back of the oven control and remove the multi plug, check for corrosion, clean contacts, and reconnect securely. Check the ribbon connection between touch pad and control board (if applicable). Retry
Jan 21, 2010 | Kitchen Ranges
Oven button doesn't work, we can get broil but not oven
Check underneath the bake panel and make sure the ignitor bar is glowing when you set it for bake.
Jul 06, 2009 | Whirlpool GS460 Gas Kitchen Range
Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Jan 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Dec 02, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Sep 28, 2008 | Whirlpool GY396 Electric Kitchen Range
The control panel on my gas range does not work the light clock works the stove works but the bake and broil does not i cant get the oven to start and it is not self cleaning but it has a lock button it...
IF ,WHEN YOU SELECT BAKE ,DOES THE BAKE COIL GLOW RED??????? IF YES IS CORRECT, THAN REPLACE THE BAKE COIL(IGNITER).SAME FOLLOWS FOR BROIL. PLEASE RATE THIS!!!
Jun 06, 2008 | Whirlpool Kitchen Ranges
GE Profile JGB97 Self Cleaning Oven Controls won't work
It sounds like the controls have been placed into a lockout mode. If your model is a JGBP79 do the following:
1) Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the
display shows SF.
2) Press the SELF CLEAN pad. The display will show LOC OFF.
Now here is where the directions are kind of confusing, I will give it as they say it:
3) Press the SELF CLEAN pad again. The display will show LOC.
4) Press the START pad to activate the control lockout feature and leave
the control set in this special features mode.
Seems to me if its locked already, you would just do steps 1 and 2. And if you wish to lock it do steps 1 thru 4.
Jan 26, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
