Question about Icon ProForm 515 TX Treadmill
Proform 515 TX; no power to motor; display shows time elapsing and distance traveled. What is the likelihood that the controller is bad?
    Top Expert:
  • Icon Master
  • 12,223 Answers
1) test the terminal motor with VOM, if there are Voltage the motor is faulty.
2) test the output voltage coming from control board, if there are Not voltage for to input voltage motor, the board is faulty.replace
God bless you
Posted on Oct 14, 2013
Sportsart 1080 treadmill error 01
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Mar 17, 2014 | Proform Power 1080
Proform 480E treadmill doesn't work
Check your drive motor with a 9v battery....if it turns, your controller is likely bad, provided your wiring harness is not damaged. Call 877-805-1030 if you need on site service.
Dec 24, 2013 | Proform Exercise & Fitness
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
What determines a car for service
Generally time elapsed, or distance travelled, whichever expires first.
Aug 09, 2013 | 2006 Toyota RunX 140i
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
When I turn on my proform 650 cross trainer the display shows 8s and flashes brightly one time and then goes blank
1) tRY TO exchange new batteries by news one.
2) Use your calibration software by easy diagnostic and fix it.
3) Tight the flexible cord from key piney vs display board.
4) Tight the connector from display board vs, Main Motor board,
5)aTTACHED THE diagram for sensor reed switch adjusted by 1/8"
6) Test the main motor controller board for 115 Vca,
+5vdc FOR OUTPUT GOING TO DISPLAY BOARD.
7) tEST THE transformer see the tips.
8) Test the power supply for +5Vdc see if there are some componnet like resistor, capacitor, diodes, etc Burns.
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness12_26_2011_4_50_52_pm.gifSee the block diagram for easy diagnostic that I did for people like your. Sincerely. Happy New Year G-d bless you.
ernesto cuadra
managua, nicaragua,
Dec 20, 2011 | Proform 650 Crosstrainer Treadmill
Every time I put the key in my Proform 590T, the incline rises for a second, and lowers for a second while displaying 2 hash marks. Then, the home screen comes. All speeds work fine for walking/running,...
how long have you had this treadmill? usually when the hash marks appear it means that the console control board is not recognizing the incline motor. even though it does run a little bit that is just the basic test that the treadmill starts but resets after it does not sense the incline motor. These motors rarely go bad so it is more than likely your motor controller that is causing the issue. I have seen this case many times as i am a fitness repair technician. The motor controller fixes the issue 9 times out of 10
Aug 05, 2010 | Proform 590T Treadmill
Pro form 515 changes speeds on its own periodically
It sounds like you have a short circuit in your controller. Unplug the treadmill and remove the motor hood cover. Now find the speed control that gives you the signal from the controller to your motor. Unplug the connector from the controller and replace the motor hood cover. Now plug in the treadmill. If it still speeds up during power up, you have a bad Controller.
Aug 17, 2009 | Proform Exercise & Fitness
Icon ProForm 515 TX Treadmill Logo
53 people viewed this question
Top Icon Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Alienware X51
Alienware X51
Level 1 Expert
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
