Question about Refrigerators
I have a 12 year old sub zero 590 side by side. The freezer is not working well.ice is fine but ice cream is very soft. Meats and others are not so hard either.
    Scholar:
  • 50 Answers
Jai,
If the ice is still frozen after any time the temp is below 32. But thats not cold enough as you know. Target temp in such a freezer is between +10 to 0 F inwhich ice cream is good and firm. BTW many restaurants and food pro's set and judge the freezer temp by the firmness of ice cream! A twelve year old Sub Z should not be having such problems and causes could be numerous. Lets talk about what you can do. This is a built in unit correct? Ok, get your step ladder and remove the cover above the doors and look for a dirty coil, a failed fan, or both. If the coil is dirty enough to restrict air flow or fan not blowing this IS a problem! One that will cause such problems and is my bet to whats going on.
Posted on Oct 14, 2013
fridgetech
  • 473 Answers
SOURCE: New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Posted on Oct 07, 2007
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
mikedurland
  • 481 Answers
SOURCE: Admiral model #rswa278a
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Aug 08, 2008
  • 56 Answers
SOURCE: Sub-Zero 550 water dripping on right side of freezer forming ice on draw
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
wheelshot
  • 102 Answers
SOURCE: sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Posted on Apr 11, 2009
What is causing my sub zero moled 590 , made in feb 93 to gradually warm up?
yeah vacuuming behind the fridge is a good start this will help the fridge preform better as when dust builds up on the condenser it will cause the discharge to be hotter than it should be making the cooling in the case not as efficient. i would start by removing the pannel in the fridge and seeing if any ice is on the evaporator
May 22, 2014 | Sub-Zero Bottom Freezer Refrigerator
My freezer does not keep my ice cream hard, yet it freezes meats, etc. without a problem. What is wrong?
You don't note whether or not you've adjusted the thermostat. Ice cream (and juices) requires at least zero degrees, if not minus 5 degrees, for storage. Meats, fish, bread, etc. can become rock hard at much higher temperatures. Try setting the thermostat lower.
Jun 07, 2011 | Freezers
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Our sub zero seems to defrost in cycles. Not sure why ice cream melts in there while other meats remain frozen. Is this an expensive problem?
The defrost may be lasting too long....and ice cream is always the first thing to melt... you need at least 10 F to keep ice cream hard...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | Sub-Zero Freezers
Freezer is not maintaining cold temps and ice machines is not wor
this type of problem is better you call a tech and if he cant fix it get all info you can and re post it at fixa
Apr 09, 2010 | Sub-Zero 695/O Side by Side Refrigerator
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Jul 30, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub zero #590
Have a small water leak up top on left hand side and looks like it could be a small plastic hose?
Dec 25, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
