Hi, I got a tp-link 8901g, but no pin code exists behind the router. Only there is a P/N on its pocket with 10 digits, while I need a 8-digit pin for configure my wireless network. What should I do? Please guide me. Thank U!
    New Friend:
  • 126 Answers
The pin will be printed on a label underneath the router
Posted on Oct 17, 2013
    Master:
  • 359 Answers
If you are configuring your wireless network for the first time there should be no pin required, if there is it should be listed in the manual of the device. If you received this router second hand then you will most likely need to perform a factory reset on it to remove any passwords the previous owner may have set. The default login to the router to access all of the router configuration is user: admin password: admin. To factory reset the router you need to hold the reset button with a pin/paper clip while powering the device on and continue holding it for 15 seconds after powering it back on. This should wipe out all configuration and let you back to stock parameters where you can access the router at 192.168.1.1 and use admin/admin to access and reconfigure your wireless settings from scratch.
Posted on Oct 13, 2013
oldnovii
  • 667 Answers
SOURCE: Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 31, 2008
Kuwagata
  • 181 Answers
SOURCE: have a d-link router with password. Ipod touch(8G) won't connect
Try remove the password on D-Link router, put it on open conditions (no security enabled).It should work.
If still won't connect, try using laptop or any wireless device to connect to router(without password), if connect, then there's something wrong with your Ipod.
Posted on Dec 08, 2009
perpetually
  • 360 Answers
SOURCE: Where is the 8-digit PIN number for the Linksys
I am guessing you are talking about the WEP/WPA key so you can allow a computer to use the wireless.
Click on this link http://192.168.1.1 on a computer hooked up to the router, if the wireless is not working, connect directly to the router via an ethernet cable.
You will be prompted for a username and password. If you have not already changed the username and password, the username will be left blank and the password will be "admin".
Once you are into the configurations for your router, navigate to the tab called "wireless", then navigate to the sub menu of "Wireless Security". The "key" you are looking for is listed right there.
Posted on May 02, 2010
  • 4 Answers
SOURCE: My motorola surfboard router/modem has
I had the same problem and i think i remember how to solve it. When you are ready to enter the pin # (the one that has to be 8 digit long0, ignore it and instead click in the bottom part of the window where it say something like 'enter key phrase/password instead' and then it will ask you to enter one. The password is listed in the label on the bottom of the router. It is the long one under 'WPA-PSK." I hope that helps.
Posted on Aug 12, 2011
  • 477 Answers
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Posted on Mar 08, 2012
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
What is the 8 digit pin code of TP-LINK_87524C?
The pin code should be printed on the router itself. Each one is different.
Oct 18, 2014 | TP-LINK Computers & Internet
Router 8 digit pin number
go into the router page at: http://192.168.1.1 or http://192.168.0.1 or http://192.168.2.1 login then go to wps, thats the 8 digit pin. You can hack it using a rtl8187 wifi adapter, linux, aircrack-ng, and reaver-wps to crack the pin but it will take 6-8 hours from what I've read.
Nov 03, 2013 | D-Link Xtreme N DIR-655 Wireless Router
TD-W8901G issue after upgrade to V6
I'm an electrical and electronic engineer (Iranian and Persian native speaker) that had the same problem,exactly my modem went to death (just power LED is ON) after upgrading from version 3 to 6 and I have precisely similar TP-LINK TD-8901G ADSL2+ router but I found a great "step by step" tutorial in a Russian website(in their forum) which contributed me significantly;
I hope it might help you too.
iman28aban@gmail.com
+989358817467
http://www.lan23.ru/forum/showthread.php?t=6859&page=1
Dec 27, 2012 | Computers & Internet
I am using a tp link 8901g router. my desk top and one of our laptops both work on wireless but our acer aspire lap top finds the router but does not ask for the wap key but will not connect it will...
Try going into the system then device manager uninstall the wifi driver. Reboot the pc and it should auto load the driver when getting back on the desktop. Then see if it ask for the WEP key
The wifi driver will say 802.g 111 or something so you know its not the 10/100 network.
Apr 30, 2011 | Computers & Internet
My D-Link DSL-2740B modem Router is already installed and working for all the computers but trying to hook up the Vista OS computer and wireless access is asking for to enter 8 digit PIN. I can not find 8...
Well the PIN number is Usually on the router itself on the back side and its a 8 digit number if that works well and good. Open an Internet Explorer browser page on your wired computer(desktop).In the address bar type - http://192.168.1.1 and press Enter... Leave Username blank & in Password use admin in lower case...8 Dec 2011
Need PIN number! - Networking, Internet, Wireless Forum ...
en.community.dell.com/support-forums/network-internet-wireless/f/3324/.../19426225..or go to this link and see if it helps you find were it is..... Link DSL 2740B modem Router pin number Google Search
Oct 23, 2017 | Computers & Internet
Where do I find the 8 digit pin if I don't have the original manual?
This link should give you more information about your network including the network key ( 8 digit code )
Link
Nov 03, 2010 | 2wire HomePortal 1000HW DSL Modem and...
A pin code does not existed on my router. How do I find it?
Hi friend,
If you turn the router upside down, you will see a six digit number that is the pin code.
Regards
Chiranjeet
Oct 04, 2010 | Computers & Internet
I have lost my manual help please geoffannatkins@wanadoo.fr
Nokia 6300 User Guide
1. General information
Access codes
Security code
The security code (5 to 10 digits) helps to protect your phone against unauthorized use. The preset code is 12345. You can
change the code, and set the phone to request the code. See "Security," p. 28.
PIN codes
The personal identification number (PIN) code and the universal personal identification number (UPIN) code (4 to 8 digits) help
to protect your SIM card against unauthorized use. See "Security," p. 28.
The PIN2 code (4 to 8 digits) may be supplied with the SIM card and is required for some functions.
The module PIN is required to access the information in the security module.
The signing PIN is required for the digital signature.
PUK codes
The personal unblocking key (PUK) code and the universal personal unblocking key (UPUK) code (8 digits) are required to change
a blocked PIN code and UPIN code, respectively. The PUK2 code (8 digits) is required to change a blocked PIN2 code. If the codes
are not supplied with the SIM card, contact your local service provider for the codes.
Barring password
The barring password (4 digits) is required when using the
For more information you can download through this link. http://www.o2.co.uk/deviceinfo/device-pdfs/nokia6300eng.pdf
May 13, 2010 | Nokia 6300 Cellular Phone
WHAT IS THE DIGIT NUMBER MY D-LINK DIR-615 ROUTERS?
if you are referring to the wireless security passcode pin number , its usually written on the bottom of the router.
Mar 13, 2010 | D-Link DIR-615 Wireless Router
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
