Set tax rate on Sharp EL 1801V - Office Equipment & Supplies
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Posted on Dec 04, 2008
SOURCE: SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Posted on Apr 10, 2009
SOURCE: NEED TO SET TAX RATE
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5% you enter 9.5, STR, TAX+.
now it functions as (amount entered) plus tax. Example- find the total with tax for a purchase of $14.99 14.99, TAX+ Calculator will show 16.41
Posted on Apr 16, 2010
SOURCE: HOW DO SET TAX RATE
Easy. Press M- key [has RATE SET] above it. This will shown your current setting say 17.5. Amend to 20.0 and Press M- key again. Rate should now be set at 20%.
Test by entering:
100 and pressing +TAX key - Answer should be 20.
100 and pressing -TAX Key - Answer should be 83.33
Posted on Jan 06, 2011
How to set date??? and to put in the tax. on a Sharp EL-1801V??
Here is a link the operations manual. In the first column is the instructions for changing the Date, Time, and Tax rate.
I hope this helps. Have a great day.
PS - Please be sure to let me know if this worked or not.
Jul 11, 2011 | Sharp Office Equipment & Supplies
HOW DO SET TAX RATE ON SHARP ELSI MATE EL-2125
Test by entering:
Jan 04, 2011 | Sharp EL-330AB Calculator
How do I change the date on a Sharp EL-1801V calculator?
Below is the step by step directions on how to update the date/time/tax rate. To set the date, time or tax rate, set the "Grand Total/Rate Setting Mode Selector (GT . RATE SET) to "RATE SET" position.
For Date:
1) Enter in the order of month, day and year, with the decimal point in between each set of numbers. Month 1-12, Day 1-31, Year: 2000 - 2999 (4-digits) or 00-99 (2-digits).
Example 04.10.2010
2) After the year, press the button with the clock/calendar symbol to complete the entry. When this button is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored.
For Time:
1) Enter in the order of hour, minutes with a decimal in between the hour and minutes, then press the button with the clock/calendar symbol to complete the entry. (No seconds value is entered) When this button is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hours must be represented with 0-23 (24-hour system for the hour entry), Minute: 0-59.
FYI, This calculator uses CR-2032 lithium battery.
Enjoy!
Apr 10, 2010 | Sharp EL-2630P Calculator
TAX SET
Press +TAX
press the number you need to set it at
Press +TAX again then CA
worked for me!!
Hope this helps
Oct 21, 2008 | Sharp EL-1801P Calculator
Jun 05, 2008 | Sharp EL-2192Rll Calculator
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
RATE SET(+TAX Key)
CA
C.CE
C.CE
May 01, 2008 | Sharp EL-330AB Calculator
Sharp EL-1801V Calculator
Change the switch to Rate Set, then input the mm.dd.yyyy then the clock/time button then hrs (military time).minutes then clock/time button.
Apr 02, 2008 | Sharp EL-2630P Calculator
It is glorious!!!
Jan 20, 2008 | Sharp EL-1701C Calculator
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
Sharp EL-1801V 12 Digit 2 Color Printer
if your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
Nov 01, 2007 | Sharp EL-2630P Calculator
75 people viewed this question
jasbo
jasbo
