Question about Zenith DVB412 DVD Player
I have a Model DVT412/dvd.cd player AM-FM receiver with speaker system and the CD player isn't working and wanted to know where I can get it repaired. e-mail is janeb5@frontier.com phone number is 618-262-8944. Thank you. Jane
2 Suggested Answers
  • 814 Answers
SOURCE: My dvd player model dvp615 doesn´t play dvd discs.
You need to try to clean the laser head and the transport. To do this you will need cotton swabs, isopropyl alcohol and small cans of lithium grease and compressed air.. Open the up the compartment that the dvd discs are placed. In the center of the compartment you will find the spindle and a laser transport. In the transport you will see the laser head. Take a cotton swab and put a small amount of alcohol on the tip. Rub the tip of swab gently across the head of the laser. Do this until the head look bright and shines. Use the other end of the swab to dry the excess moisture off the laser head. Take another swab and use a small amount of alcohol on the tip and go around the transport device cleaning the dust and dirt from it. Use a small can of compressed air to blow away any dust and dirt in the compartment. Once the laser head is cleaned and the transport is cleared of dust and dirt, Move the transport to the outer most point and bring it back in to its closest point. Do this several times. Do not apply to much pressure while doing it.If you find ruff and uneven action. Clean the areas of problem and return the transport action to smooth and easy operation. If still not smooth and easy. Take another cotton swab and use some lithium grease in very small amounts to lubricate the transport rails. Again move the transport back and forth to lubricate the laser transport. This should return the transport to normal action. Now play a music cd to calibrate the laser head . Let the cd play through a couple of times. After doing this you can now try a dvd disc and it should play normally. If it still does not play correctly, check the spindel to see if it is loose. If this is the case use a drop of super glue to tighten it up. Let it dry completely and try the disc again. It should work correctly. If you are still having a problem.You either have a problem with the laser itself or the drive motor. The drive motor problem would usually be noticed on the playing of the cd. The laser head and the motor can be replaced if this is the problem. You can find more information on how to do these repairs on you tube. Put cleaning and repairing portable dvd players in the search engine and it will bring up videos on how people have done these types of repairs. I hope this information will help you with your problem.
Posted on May 30, 2009
To add to my request a manual for AWA 17cm DVD/CD/AM-FM Television Micro System
An FM transmitter is a portable device, which converts a specific audio output into an FM radio signal. It can be plugged into a CD player, satellite radio system, headphone jack, or a portable media player. One common use of an FM transmitter is to play music from an Mp3 player through the speakers of a car.
Aug 20, 2012 | Televison & Video
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
http://www.pyleaudio.com/sku/PD1000A/1000-Watt-AM-FM-Receiver-w-Built-in-DVDMP3USB
Jul 10, 2011 | Audio Players & Recorders
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
Cd music is skipping on bose 321 system and one channel of dvd audio will stop playing. Disk player has also started making loud vibration noise after loading dvd or cd. This didn't used to happen. On CD...
The Bose® 3·2·1 GSX Series III DVD home entertainment system puts you at the center of exciting home theater with just two visible Gemstone® speaker arrays and a hideaway Acoustimass® module. Setup is simple because, unlike traditional five-speaker surround systems, there are no center or rear speakers. An elegant media center features a progressive scan DVD/CD player with an HDMI output and AM/FM tuner. You'll enjoy vivid detail in your movies and sports with video resolution up to 1080p over HDMI.
Apr 04, 2010 | Bose 3 2 1 GSX System
How do I wire my tape and cd player to same speakers?
There are really only 2 options.
#1 Buy a fm modulated CD changer. This will allow you to play CD's over a FM frequency, and will use your factory radio as the output.
#2 Again you can buy a stand alone FM modulator with RCA inputs, and use an aftermarket CD/DVD player as a source.
Aug 09, 2009 | Car Audio & Video
Aux inputs
chek your wiring and your speaker.nad of coars the sound output of your dvd
Feb 01, 2008 | Pioneer DEH-P2900MP CD Receiver...
Surround sound
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Jun 07, 2007 | Onkyo HT-SR800 System
Zenith DVB412 DVD Player Logo
20 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
