Question about Onkyo TX-SR576 7 Channels Receiver
Onkyo TX-SR576 Receiver, Zone 2 left hand speaker cuts out on low volume. Changed speakers and completely rewired directly from receiver to speakers with no intermediate connection points, +ve & -ve double checked. Still cuts out at low volume. When turning on Zone 2 on low volume, speaker cuts in as volume is raised. Any ideas please
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Onkyo Master
  • 924 Answers
The contacts on your speaker relay are oxidized or burnt. If you can get it out, you may be able to burnish the contacts, then use LPS-2 on it. Don't push the button on the can too hard. You only want a small amount of foam. If burnishing the contacts isn't successful, you may require a new relay. If you require more assistance, or would like to inquire about repairing your Onkyo, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Posted on Dec 23, 2014
  • 163 Answers
Bad soldering joints inside the receiver or faulty speaker relay.
Posted on Oct 14, 2013
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: the onkyo tx-sr576 receiver turns
Well, duh, check out the speaker wiring in Zone 2 for shorts.
Posted on Apr 24, 2011
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
Onkyo TX-SR605. Low or no sound output
Does any good sound come through headphones, if you plug any in?
Apr 24, 2017 | Onkyo TX-SR605 Receiver
Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Jun 21, 2009 | Onkyo Audio Players & Recorders
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Mar 08, 2009 | Onkyo TX-8511 Receiver
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
Left Surround Channel
Try to tighten the screws at the back where you insert your A/V jacks.
Thanks!
Apr 10, 2008 | Onkyo TX-DS575 Receiver
Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Jan 23, 2008 | Onkyo TX-SR500 Receiver
Onkyo TX-SR576 7 Channels Receiver Logo
184 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
