Question about Water Heaters
Water does not go into the container please help
    Sergeant:
  • 222 Answers
In order for the air to escape from the empty tank, which is displaced by the incoming water, you must open a hot water spigot somewhere in your plumbing system. Really doesn't matter which one, although I often look for the one most distant from the water heater to be sure that all the air is out of the lines as the water heater.
Posted on Oct 15, 2013
I have very low water pressure.
Water Pressure or Water Temperature?
Water Pressure your service pipe must contain some impurities which have blocked the outlet pipe of water, check the pipe if water pressure is not coming upto the mark....
Oct 30, 2016 | Water Water Heaters
Why no power to pump?
[PDF]residential hybrid electric heat pump water - AO Smith Water ...
www.hotwater.com/.../hybrid-electric-heat-pump-service-handbook-(32...
... MAINTENANCE -. OPERATION & SERVICE - TROUBLESHOOTING ..... Tools for servicing residential electric heat pump water heater models: • Container (to ...
How to troubleshoot electric water heater - Water Heater Timer
waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-...
How to troubleshoot electric water heater. ... 2) Heat pump electric water heater has fan and compressor and will make sound when operating Read 3) Clean ...
Jan 01, 2016 | Water Heaters
The water does not exit out of the container also
Tell me more of what your problem is?
To get water OUT of a Hot Water Heater, you have to push COLD water in-- So the water pressure in the house water system is the moving force that moves Cold water thru the heater, and comes out at the Hot Water Faucet, HOT!
Tell me more what you problem is?
Mack B
Oct 13, 2013 | Water Heaters
Does celltone contain hydrogen peroxide?
Natural remedies that remove blackheads
Blackheads can become a challenge - if you do not know how to remove the unsightly phenomena.
Blackheads are bumps in the skin that are caused by an accumulation of excess fat and sebum in the skin glands. When the fats oxidize, they become darker and give the blackheads their characteristic color. Although blackheads can be emptied quickly by squeezing, they cannot be removed permanently.
Aug 07, 2013 | Water Heaters
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
I have a rheemglas standard electric 40 gallon water heater and the hot water in the shower or any where in the house only last 3 maybe 4 mins.....?
You should have two panels on the front of your water heater most likely painted blue. Each of these panels contains a heating element. The top panel contains the reset switch. Unscrew and remove the top panel and you'll see the reset switch - it is the red button. Press it to see if it clicks. If so, your hot water should last longer.
If it does not last longer than you stated, then you most likely have a bad heating element. The problem is that unless you remove both elements, you won't know which one is bad. If you don't feel comfortable turning off the water valve to the heater, turning off the power to your water heater at the circuit breaker box, draining the heater of it's water using a garden hose, removing the wires from the elements, removing the elements and installing new ones from your home improvement store then you may want to hire a plumber to do it.
The process is fairly easy but time consuming. The most time is draining the water heater. If you do choose to do it yourself, you will need to get a special "wrench" from your home improvement store to remove the heating elements first. The store can help you with the element(s) you need once you take them in.
Regards
Apr 05, 2011 | Rheem Water Heaters
Yesterday morning I turned the water on to get in the shower and realized the hot water wasn't working I figured it was just something little but this morning I realized that the hot water is still not...
If this is an electric water heater, you should see a little access panel on the side. This contains the thermostat and, most importantly, the circuit breaker. It'll be a little red button you push in. If it pushes in, you've found your problem and you then enjoy a nice, hot shower!
I hope this helps! :)
Jan 07, 2011 | Rheem Water Heaters
Ariston ACO MFFI 35 E34 fault code present
This is the manual for your boiler. I hope the information contained in the manual will help you identify your problem.
http://www.ariston.co.uk/uploads/doc47e92b04013d8.pdf
Mar 30, 2009 | Water Heaters
My electric water heater tank just started shooting water out of the pop-off valve. I turn of the water ''ALL CLEAR- PLBG AND CLEANING'' LEVER and it stopped for now. In turn, water started leaking from...
PLEASE TURN THE POWER OFF TO IT NOW!!!!
Sounds like the thermostat is bad and it is over heating. So please turn the power off till you can look at it. If it stays liek this and that is the problem you can kill someone and also blow your house up.
Mar 27, 2009 | Water Heaters
Water Heaters Logo
14 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
