Question about Garden
1320 Ford tractor PTO does not engage while the motor is running but locks up when it is not running. Will back spin the motor when not running but when running you can hold PTO shaft still.
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 376 Answers
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
Posted on Jun 08, 2009
mickey813
  • 472 Answers
SOURCE: I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Posted on Sep 30, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
Any adjustment for hino dutro tipper pto.
When engaging the pto it is important that you have the clutch disengaged so that the pto gear is not spinning in the box.before it engages.
The pto gear runs off the counter shaft of the gear box and is spinning all the time the engine is running
when engaging the pto ,you are physically engaging a gear ( like selecting 1st gear) so you have to stop the counter shaft spinning so that the pto gear will engage with slashing
Jun 14, 2015 | Garden
Ford 5000 pto
i believe the lever is on the left side that operates the pto. on some models it will have a plate stating its the pto, you'll have to start the tractor, and engage the clutch, then engage the pto, and release the clutch. Others you simply engage the pto once you've started the tractor
Jul 17, 2014 | Garden
Husqvarna 17530 stalls when engaging the blade. Seems to run fine else wise/
Does engaging the pedal for the PTO lug the engine down, or does it just die like turning off the key?
If it lugs the engine down, then you need to make sure you can spin the spindle and idler pulleys by pulling the belt by hand. You should be able to slip it around the engine pulley enough with the blade pedal disengaged. Pull the belt up tight so the slack is around the engine pulley and try to spin the blade spindle and idler pulleys.
If it dies like turning off the key, then its likely a safety switch and may require a meter to test which.
The seat switch is has a shunt in the circuit that must be satisfied in order for the rest of the circuit to be happy. Make sure the connections are good, the pins inside the amp connectors will sometimes spread, push out of the lock etc. and if connection is lost will not work. Otherwise a new seat switch will be needed. You might check the PTO switch for continuity, without a diagram or schematic I am not sure how your circuit is wired. you have to have the parking brake engaged to get off the mower while the engine is running and the PTO is Dis-engaged?
I don't know if your "go" pedal eliminated this switch or not. But if with the parking brake engaged and the PTO disengaged, you lift off the seat and it dies, then its the seat switch.
Hope this helped Tim
May 21, 2011 | Husqvarna 24HP 54" Yard Tractor ()
When we engage the pto switch, on our Ford YT16 42" cut, the mower deck does not operate. Is this a pto switch issue, clutch issue, or something else? How do we fix it?
Could be the switch. This model may also have a relay I'm not sure because of the age. There is also a seat switch that has to be made for the PTO to work. I f you have a 12V tester, with tractor off, disconnect wire from the PTO. Start motor, have an assistant sit on seat and turn on PTO test wire for voltage. If none present, then trace wire back, to either the switch or relay. There also should be a fuse in the circuit. By the way these were cool tractors.
Aug 18, 2010 | Ford Garden
PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Aug 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
My PTO will not engage without grinding but works great once engaged, Model is only shown on the engine as C10 with production code of 5F5B and serial A281771
when u engage u have to push in clutch and wait for spinning gears to stop the engage pto and let out clutch, excessive spinning of gears can be caused by low transmission grease also causing grinding
Apr 13, 2009 | RTO Ford Tractor 2000 3000 4000 5000 Water...
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Engine dies when engaging PTO switch on a John Deere GT235. I have replaced the seat switch and the PTO switch.
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Feb 21, 2009 | Garden
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
