Question about Water Heaters
Jacuzzi z112 - Water Heaters
    Master:
  • 383 Answers
What is the problem you afe having with your Jacuzzi Water Heater?
Is this a Jacuzzi Hot Tub?-- Do you have some indicator lights on?-- what color are the lights?--
Is the Circulating pump running water thru the heater element?
Tell me more!-- Let's walk thru the system, and figure it out-- Mack B
Posted on Oct 16, 2013
2 Suggested Answers
co7196
  • 3433 Answers
SOURCE: Hello, how I remove the water from my whirlpool
hook up a garden hose to a faucet. Put the other end in your spa. Then turn on the faucetuntil water comes out the spa end of hose. Make sure the end in the spa is weighted down so it doesn't come out. Then remove the hose from the faucet and keeping it lower than the spa lay the hose where it can drain with causing problems. The water will flow on its own draining the spa. You may want to clean it while its draing so the dirty water will be diluted and drain at thhe same time. Make sure the water is not drained out around any electrical AND!!! NO DIVING!!!! If you lose the prime, just fill the hose again with the faucet. Good luck
Posted on Jun 18, 2009
Earth leakage trips when i switch on jacuzzi
There is a ground fault somewhere...you need to isolate it with an ohm meter.
Dec 02, 2013 | Jacuzzi Water Heaters
How to wire a jacuzzi whirlpool tub? What to use for wiring, timer etc?
get an electrician. you need to follow the code for the size of wire to use based on number of amps of the motor and how far away the pump is from the power outlet.
Sep 29, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Hello, how I remove the water from my whirlpool jacuzzi bath Balboa Z112 spa so I can clean it
Jun 12, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
My Jacuzzi won't turn off or heat
The heater will only fire if it has water in it. If you just got the house, make sure the gas/electric to the heater is on. Turn off the pump and turn it back on.. See if that works. good luck
Jun 05, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Whirlpool jacuzzi jets not working properly
im not a great expert in this field but try putting some dish washer tablets in water when running to see if they can clean out anything,about 3/4 tabs
Mar 03, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
The Jacuzzi isnt recieving power
yes it could, it might even be the motor, take the electric suply and unplug it see if you can turn the shaft on the motor if not it froze up,, sometimes the get wet and seize, the you have to get a new motor
Feb 27, 2009 | Jacuzzi Allusion 7242 RH Whirlpool HTR...
Black soot in my jacuzzi tub
sounds like the rubber seals are going bad, does it recomend to run cascade thru the jets? this might be harmful to the gaskets and the pump, you maight want to disconnect the hose and flush out the tubes going around the tub, but I would call jacuzzi and ask them if this is good to run thru there, thye might be able to help you with the gaskets, questions over the phone do not cost you, call them, ask for repairs section good luck
Feb 27, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Water Heaters Logo
44 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
