Question about Dream Maker Spas Dream Maker SpaDition Vico Pump 15 HP ()
I set my temperature for 102 and the temperature light flashes 104 when the temp is freaky 97. I have reset it and this continues. I do not get an OH sign or any any other letter telling me anything.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dream Maker ... Master
  • 1,448 Answers
Should be a calibration adjustment in menu
Posted on Apr 19, 2014
Just installed new rs8pcb and temp sensor. Set at 104,only reaches 102, why?
Try calibrating your Jandy controller to the temperature of the heater. Temp sensor could be off by two degrees
Dec 04, 2016 | Pool & Spa
My spa temperature light is blinking. It is set at 104 and the temperature is showing 118. Why is the temp blinking?
If you can contact your spa manufacturer they will usually send you the manual for your unit at no cost.
If the temperature is set at 104 it is at the high end of the safe temperature for a human. 102 is recommended, and 103 is OK for 15 to 20 minutes maximum.
If your spa is actually at 118 degrees, it could easily cause very severe medical heat distress. I would strongly recommend NOT using it until you can get the temperature down.
It's possible that the blinking light is a warning.
Jun 14, 2015 | Intex Pool & Spa
South seas spas
need more info. will temp lower? if temp lowers try setting up to 104 if desired temp will not increase sounds like you need temp adjustment switch if desired temp goes up to 104 but water doesnt
sounds like temp sensor if temp sensor is good heater element
Feb 16, 2014 | Pool & Spa
Jacuzzi j210 heater
bad temp sensor replace
Feb 01, 2014 | Qca Spas Pool & Spa
I have Marquis hot tub, Leisure Series, The Spirit, Model ESLS30X, serial # 0890608. My in-laws gave it to us. It's about ten years old but still works reasonably well. The one issue is water...
If you found a solution to this problem, can you tell me what it was? I have the same thing. Its a Marquis Spririt and it just doesn't get hot enough. There must be a way to "trick" the thermostat into letting the heater run longer
Dec 10, 2010 | Heating & Cooling
Savannah spas
probably a dirty filter!! take it out turn tub off to reset turn back on with filter out and c if nthis solves problem if so replace filter.
Nov 20, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
97 saturn sl2 temp light flashing and low coolant light flashing what could be the problem ? coolant is full and the heat works.
If the temp gauge is reading normal, the lights are flashing, and the coolant level is full, the level sensor in the coolant bottle is the problem. I'm a service consultant for a Saturn dealer and I've run across this many times.
Apr 17, 2009 | 1997 Saturn SL
Dream Maker Spas Dream Maker SpaDition Vico Pump 15 HP () Logo
102 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
