F&P Model GW 52-K spins perfectly without water but won't spin with water - just hums. Have checked black hoses and removed diverter cap and can only think that blockage is under the central barrel/agitator. How do I remove this to check?
  • Shirley Conway
    Shirley Conway Oct 13, 2013
    It does spin with the water out and I checked the trap and it's clear. I'm sure it's at the bottom of the drum but I can't get to it.
    Master:
  • 818 Answers
Have you checked the trap-it should not spin until the water is out-
heers Dennyc
Posted on Oct 13, 2013
4 Suggested Answers
  • 96 Answers
SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
Posted on Mar 13, 2008
SOURCE: Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Posted on Jan 22, 2009
  • 181 Answers
SOURCE: I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
Posted on May 14, 2009
My smart drive 5 fresh wont spin
You should be getting an Error code 37 pump faulty.
37.
(00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3 minutes. There are three likely reasons for this fault. One is that the drain hose or the pressure switch hose has been squashed or kinked and the pump out rate has been dramatically reduced. The second possibility is that the pump is partially or fully blocked. The third is that the pump is not operating due to Motor Control Module, wiring or pump failure. This fault could also appear if the machine is pumping to an unusually high head of drain hose or into an extended length of drain hose. The fourth possibility is a diverter valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation mode, giving the module the appearance the pump is not lowering the water level.
Primary Source:
Action:1)
Pump System.
Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 39.36in / 1 metre extension hose of the same diameter fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the basket is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain hose is not blocked.
5) If the basket contains water, then service the pump from the top of
the machine by removing the top deck and inner basket. Bail out the water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action:
Tertiary Source:
Action:
1) Check the pump harness is connected correctly to the pump. 2) Check continuity of the pump harness.
Motor Control Module module.
Activate the pump by operating the machine in spin mode. Check the pump is rotating. If it is not operating, and Primary and Secondary checks have been performed, then replace the Motor Control Module.
Jun 10, 2013 | Fisher and Paykel Washing Machines
F&P MW511 HELP beeping and not draining
You have a blockage in the drain hose or pump,
Try to drain all the water out before you remove the pump
Error Code 37,
37. (00100101) Phase 1 to 6 - Pump Blocked Error ( No change in the water
level)
Controller module, wiring or pump failure. This fault could also appear if the
length of drain hose. The Fourth possibility is a diverter valve fault or blockage,
Primary Source: Pump System.
Action:
1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if excessively
long. A 1 metre extension hose of the same diameter fitted to the existing
3) Check for open circuit windings in the pump. (Note: Pumps are fitted with a
thermal cut-out which will reset on cooling.)
4) If the bowl is empty of water, remove the pump from the pump housing and
5) If the bowl contains water, then service the pump from the top of the machine
by removing the top deck and inner bowl. Bail out the water, remove the
Action:
Tertiary Source: Motor Controller module.
Action:
been performed, then replace the Motor Controller module.
Note: Consider fitting Pump Hood Kit (WM013). If 5kg Smartdrive fit splash guard to
pump.
Jun 10, 2013 | Fisher and Paykel GWL11 Top Load Washer
My fisherpaykel top loader washing machine wont drain water or spin it beeps and 3 lights come on
I worked out that code to be 37
info for fault 37
37. (00100101) Pump Blocked Error (No change in the water level)
Action: 1) Check that the drain hose has not been kinked.
excessively long. A 1-metre extension hose of the same diameter
the machine by removing the top deck and inner bowl. Bail out the
Action: 1) Check the pump harness is connected correctly to the pump.
Tertiary Source: Motor Control Module.
Action: Activate the pump by operating the machine in spin mode. Check the
Dec 05, 2012 | Fisher and Paykel Washing Machines
GW 612 Fiaher Paykel wont complete drain or spin cycle
Do you get any errors on the display lights?
Dec 03, 2012 | Washing Machines
I HAVE A INTUITIVE WASHING MACHINE WITH CODE 37 AND A TERRIBLE BURNING SMELL IT WON'T SPIN OUT NOW
You have a bad pump.
Info for fault code 37
Action:1) Check that the drain hose has not been kinked.
length.
restriction.
Tertiary Source: Motor Control Module module.
Aug 28, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Lg wm2455h is not draining: i have taken out and cleaned pump filter and that did not correct the problem. I place the machine on the drain and spin cycle and i can hear the pump hum, but doesnt drain. ...
most likely you have a bad pump and it needs to be changed out or something is still stuck in the impellar,stick your finger into the pump and feel around the impellar,i've found under bra metal pieces stuck in there,elastics and string rapped around it and coins lodged in between the impellar and wall of the pump,if the pump is bad or something is stopping the impellar from spinning it will hum,power is going to the pump but the motor isn't spinning.
Nov 12, 2011 | Washing Machines
Model 57051A0ww does not drain (humming noise). Drains manually when hose lowered.
I'm not familiar with the model number and you have not supplied a manufacturer, however, this is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model, there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 18, 2011 | Washing Machines
Hi! we have a GW609au Fisher & Paykel washing machine with lights 3,6,& 8 displayed during spin cycle. Does not spin. What does this mean please?
It's error code 37 and it means pump blocked error. The machine does not spin because water is not drained prior to the spin cycle. Either the drain hose is clogged or kinked, the diverter valve has failed, or the pump itself is restricted or not working at all. Check to make sure that the drain hose is clear then disconnect power and lay the machine on its front on a cushioned surface to access the drain pump and the diverter valve. Remove the pump's inlet and outlet hoses then check and clear them from any debris that may prevent water from draining out. Check the impeller for any damage or restriction. Make sure the impeller is not frozen or blocked.
Also check the diverter valve for the same condition as the pump described above. The diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the diveter valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Dec 29, 2010 | Washing Machines
Fisher paykel washer wont spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 20, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
