Question about Video Game Consoles & Games
Capcom Midway 1943 - big old arcade game
The image is upside down now - not mirror image, just upside down. I'd like to get it rightside up again so I don't have to stand on my head while I play it - thanks
  • lankyyankee May 12, 2009
    Hi - thanks for the response. My friend was going to take it to the dump. He said it worked fine, and helped me put it down the basement. When I turned it on, the picture was inverted. E verything functions normally, except the whole picture is upside down. He said it never did it before.
  • aneal1200 May 11, 2010
    Is this a new development or has it always been this way since you owned the machine? Did it one day just "Flip" over? This would be an amazing feat if it did!
    Problem Solver:
  • 4 Answers
As silly as it sounds, you can probably just open the cabinet and flip the monitor over to get the picture in the correct orientation. Quite frequently arcade machine operators change out the system boards in their cabinets to keep up with the times. If they have a cabinet with an older, less desirable game in it, they'll swap it out for something newer in hopes of earning a few more quarters each week. Once in awhile they'll swap a game that has a vertically oriented monitor (like your 1943 cabinet) to something that's horizontally oriented (like Street Fighter for example). How do they pull this off? They simply open the cabinet and turn the monitor in the correct direction so the players can see it.
If you decide to turn your monitor, here's what to look out for:
First, unplug the arcade machine to avoid electrical shocks.
Monitors are somewhat fragile, and can be extremely dangerous. There is a coil of unshielded copper wire near the neck of the tube that stores charges in excess of 10,000 volts (even when the machine is unplugged and powered down), and can severely injure/kill you if you touch it. I've personally worked with thousands of monitors and haven't had an incident yet. Odds are you'll be perfectly fine, but just be aware that there are dangerous parts back there.
The monitor should have 9 wires going to it broken down into 2 bundles. The power bundle will normally have 3 wires (green, black and white) and will be a thicker gauge wire than the other set. These almost always have a white plastic connector that makes it simple to disconnect them.
The second set of wires will be the image signal wires. These will be a smaller gauge of wire and they'll be red, blue, green, white, yellow and black (in most cases). These wires also have a white plastic connector, but it's often times plugged directly into the monitors main circuit board (or chassis). Just pull the wires off of the chassis making sure you don't damage any of the components (or yourself!)
Once you've disconnected the wiring, it's simply a matter of finding the bolts that hold the monitor in place, removing them (along with the monitor) and flipping it over. The monitor should go in just as easily in either direction. Reconnect the wires, fire it up and off you go!
Posted on May 12, 2009
Why is everything upside down when looking in the simmons telescope
Most "astronomical" telescopes do invert. You can add an inverting mirror between the telescope and eyepiece, like this one:
http://www.celestron.com/browse-shop/astronomy/visual-accessories/diagonals/125in-star-diagonal
You'll get rightside up, but left/right backwards images.
Sep 07, 2014 | Optics
How to replace a arcade Big Buck Hunter Pro TV?
If your game has a CRT monitor you will have to stay with a CRT. You can get a great picture from an LCD or LED unit but the guns won't work.
May 07, 2014 | Video Game Consoles & Games
1st time user. Images are upside down. What do I do?
They are supposed to be upside down, this is how a telescope works. There are additional lenses that can be purchased on some telescopes that flip the image to make it look rightside up, not sure on yours but you can check the web or hobby shops for these. Nothing wrong with your scope, just doing what it is supposed to do.
If you find my advice helpful a vote on the thumbs up would be greatly appreciated, this helps me help more people. Thanks
Apr 04, 2011 | Meade Optics
Gamer profile permissions error.
check that your membership hasnt run out or check that family settings
Jul 08, 2009 | Video Game Consoles & Games
Picture settings
You should go to the menu and look for the "Mirror" settings, change the vertical to bring it rightside up, however if it is also backwards (horizontally) change the horizontal "Mirror" there is an option of turning on either both or each separate option. I assume though that you will probably just have to change the setting to H&V Mirror.
Apr 07, 2009 | Hitachi CP-S235 Multimedia Projector
Have two Midway/Nintendo Cruisin USA Arcade Games
first, press the menu button (inside the coin door) to enter the menu. select diagnostic menu, then dip switch test. this will tell you which dip switch (on the main board in the back) you need to change to activate the link. the switches below the link enable switch will let you know which cabinet is the master, and which one is the slave. i believe off off is the master (you decide and change it on the board), and on off is the slave game. but whatever you change will take effect upon game off and on again. also, you need a link cable (usually a usb) to link the boards.
Apr 05, 2009 | Midway Home Entertainment Cruisin'...
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Arcade Pro.EX
Works for me :) Stick's a bit rubbish compared to the older Hori sticks but it's a fucktonne better than the damned pad
Jul 15, 2008 | Midway Home Entertainment 720...
I get a mirror image
when you turn the camera the other ways and stuff.
it looks all weird. all you have to do is press
up or down on the volume key. and that will convert
the image the way you like it.
Feb 15, 2008 | Samsung SGH-D820 Cellular Phone
Video Game Consoles & Games Logo
318 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
