Question about Kodak 1950s/60s Brownie 500 8mm Movie Projector Model C Automatic Thread Vtg
Kodak m67 8mm movie projector struck in rev lever can be move to forward but miss run backwards
  • 3,446 Answers
It is hard to explain but there is a metal pin on one of the mechanisms it can become bent out of place. you need to remove it and heat it up and put back straight. dont try to bend it straight as it will snap or the pin will come out of the metal part.
Posted on Dec 31, 2013
Kodak Ektagraphic AF-1 will not advance or reverse
If the select button functions correctly, Chances are the direction lever in the mechanism is bound up or the Direction Lever Spring is broken. If the Spring is broken or the Direction Lever is bound up, the Index Lever will go out straight when the Advance / Reverse buttons are pushed - instead of moving out straight , then moving forward or reverse at a 45 degree angle.
The Slide Change mechanism needs to be re-built. The bad news is this projector was manufactured from 1976 to 1984. Kodak scrapped the repair parts in the early 1990's. Your best bet is to find a repair shop that has a projector that they can salvage parts for your projector from.... Good Luck !!
Dec 26, 2013 | Kodak Office Equipment & Supplies
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Kodak Slide Projector not moving carousel
Chances are that the LINK that connects the cycle solenoid plunger to the cycle lever is broken. This happens a lot on this generation of projectors. You can purchase the parts from: www.micro-tools.com, as Kodak no longer stocks parts. micro-tools should be able to provide installation instructions! Good Luck!
Feb 21, 2012 | Kodak Office Equipment & Supplies
Kodak 860 h doesn't drop a slide or moves forward-backward
Because of it's age, your projector needs either a solenoid link or a timing adjustment to the slide change mechanism. Either one should not be attempted documentation and training. I recommend Langie Audio-Video on Commercial Street in East Rochester, NY. They still has factory-trained technicians.
Oct 27, 2010 | Kodak Office Equipment & Supplies
Just bought a kodak 650H slide projector and i put a tray with slides on the projector but it doesn't lock in or advance.
Chances are the projector you bought needs a slide change solenoid link or at the very least, an adjustment to the timing of the slide changing mechanism.
Oct 26, 2010 | Kodak Office Equipment & Supplies
I bought a used kodak 650 carousel slide projector and i can't get the slide tray to load. Is it because it came with a 140 slide tray instead of an 80 slide tray?
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Aug 10, 2010 | Office Equipment & Supplies
Tray will not advance
The problem you describe is most likely a broken spring on the lever that moves the tray forward or reverse. The repair requires dis-assembly of the projector and the slide change mechanism and adjustment after re-assembly. I recommend you contact a factory trained repair dealer to make the repair.
May 11, 2010 | Kodak Carousel 4600 Slide Projector
Everything works except for ther forward and backward rotation mechanism. When these buttons are pressed there is a buzzing sound perhap indication a motor problem?
This is a very common problem with these old Kodak projectors and is caused by a small part called the solenoid link that can be purchased separately or as part of this kit: https://www.micro-tools.com/store/item_detail.aspx?ItemCode=KODAK-KIT
There is also a guy on eBay, "atomk", who sells kits with very clear instructions on how to repair this problem yourself. Search for "Kodak Carousel Projector ADVANCE Repair Kit".
May 03, 2009 | Office Equipment & Supplies
Kodak Brownie Super 8 Projector
in slide projector smooth movement of mechanism is rule number 1 .1-spray contact lubricant cleaner on forward and backward switches and press them many times.-open it and clean it with air blower and clean piece of clothes.apply good type of light grease in levers-cams gears-confirm all mechanical parts is in good condtion.change any broken part from nearest store.
best regards
Feb 20, 2008 | Office Equipment & Supplies
Faulty TRV-35H
general cleaning start with forward and rev button with good contact cleaner and then go inside use air blower or compresed air(radio shack)check:lever which make the movement of forward and backward confirm it is clean-check of selonid and it is return spring has a good tension change it if it is weak or broken.apply a light grease over all moving parts.
best wishes
Dec 11, 2007 | Elmo Projectors TRV-35H Slide Projector
Kodak 1950s/60s Brownie 500 8mm Movie Projector Model C Automatic Thread Vtg Logo
460 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
