Question about Dryers
Kenmore electric dryer model number 86860100
Looking for door catch/dryer door latch part number
  • 119 Answers
Door latch kit 279570. repairclinic.com has picture of it
Posted on Oct 16, 2013
SOURCE: Need schematic for Sears Kenmore Dryer model number 11063032102
Thanks, I will try that.
Posted on Mar 28, 2008
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Posted on Mar 27, 2009
pride applia
  • 232 Answers
SOURCE: Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Posted on Jul 01, 2009
  • 4088 Answers
SOURCE: kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Posted on Aug 24, 2009
Kenmore HE5 dryer. Is there an adjustment for the door, it pops open while drying. Appears that the bottom of the door hits before the top, we have to push the top of the door in to get it to latch
if the catch isn't broken sometimes i've seen the hinges out of shape,i open the door stick a screw driver in both sides at the bottom of the door where the hinges are and close the door and push on the top of door,don't go crazy just a couple of light pushes this will make the door close better,hope this helps,look at the plastic catch in the door where the strike goes into,if this is cracked or worn the door will pop open,next time open the door,find the tag and send the full model number
Dec 27, 2017 | Kenmore Dryers
I have a old kenmore dryer and it won't dry my clothes, if the rubber gasket around the door is gone will this prevent drying? Thank you Gloria
That could be the problem or if it doesn't heat up at all it's probably the heating element in it. Any local appliance supplier should have either part part in stock or look up the model online and you can order one. Replacing them is pretty easy.
Apr 08, 2017 | Kenmore Dryers
Door will not stay shut...........simply pops open after 10 or 15 seconds. No visible damage. No debris along the door pathway. Perhaps a new plastic latch. The old one looks fine.
You just need to replace the catch and the strike it is easy to install.
Detailed Viewhttp://www.easyapplianceparts.com/PartInfo.aspx?Inventory=334230&SourceCode=6 EAP334230: Door Catch Kit This dryer door latch kit comes with one plastic door latch, and one metal door strike.
Easy Part #: EAP334230 Compare At: $4.75 Your Price: $3.96 You save: $.79 Availability: In Stock 334230_1_m.jpg
Above example contains part: EAP334230.
Click image to see large version
Model number:
Part description in this model:
Part location: #
Series number: -->
334230_1_s.jpg 334230_2_s.jpg 334230_3_s.jpg function KeyPress(e) { if(e.keyCode == '13') { if(document.getElementById('_ctl0_menu1_SearchNum').value != "") { document.getElementById('_ctl0_menu1_SearchButton').focus(); } else { e.returnValue=false; //required for IE if(e.preventDefault) { e.preventDefault(); } // required for gecko } } } '); //-->
Dec 03, 2010 | Kenmore 62602 Electric Dryer
The door pops open after about 10 seconds. We have replaced the sensor that is located on the upper left inside of the door, to no avail. Any ideas? Also, I am not sure if this is the model #..
either the hinges have gotten bent from too much weight being put onto the door when it was open or your door latch might be broken, see if the white plastic door closer on the top inside of the door catches onto the gold colored latch that is at the top part of the dryer door opening, if either one of these are damaged you would replace both as they come as a kit. here is a parts listing:
http://www.repairclinic.com/Kenmore-Dryer-Latch-Parts?z=100
Nov 25, 2010 | Kenmore 600 6965 Electric Dryer
Dryer door
The dryer door catch and latch assy is worn and needs to be replaced.
See this link to see which of them matches your dryer: http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Door-Latch-Kits/index.aspx
Any local appliance parts supply center will have this part in stock. It is howe3ver best that you take your "complete model number" with you when you go to get the replacement part. They are under $3.00 in
cost.
Use a knife blade to unlock the opposing plastic retaining tabs on the old part for removal. Make sure you change both pieces. The one in the chassis and the one in the door.
Thanks for using FixYa.
Kelly
May 16, 2010 | Kenmore 63942 Dryer
I have a Kenmore Elite HE4.THe door will not stay shut. It doesn't click anymore when I push the door to close it. Any ideas?
The catch side, not the latch side, the catch on the frame may have backed off some what. It's not unusual for this to happen over time. Take a peek around the catch and see if there are any adjustment options such as two slots where the mounting screws are, a hex key slot behind it to adjust the reach and so on.With a flash light close the door very slowly and from above as best you can see if the spring fed latch is near enough to the catch. Also try hip checking the handle to try closing it.If then it latches you may have a section of seal gasket that is misplaced or swollen. See, not being there makes this a very difficult call. I've given about the most options I can think of and I hope for you guys that one of them works. Also if your closer latch is similar to the operation of a screen door latch, don't be afraid to pry the latch lightly in the direction towards the catch/latch. Good luck and Thank you, Dana
Aug 26, 2009 | Kenmore Elite HE4 Electric Dryer
DRYER DOOR WILL NOT STAY CLOSED WHEN IN USE
Most likely the receptacle that the door latch goes into is broken. Go to local appliance parts dealer with model number and buy the $5 part, or order through Sears Parts Direct online.
Jun 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer
check also,
  • the other ends of all cables connected to the relay,
    if the other end of any part of the latching circuit has loosened, the relay will not latch closed when the start button is pressed.
  • Door Switch, it is part of the latching circuit
Sep 21, 2008 | Kenmore 62872 Electric Dryer
Need help finding door latch assembly part
Go to searspartsdirect.com and type your model number in the “Search by Model Number” block. The part can be located under the “Door and Latch Parts heading as item number 7 (part number 8181700). If you need step-by-step instructions on how to replace, just follow the link below:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase on line, take the part number provided to any appliance parts retailer in your area. I hope this helps you. Please post back if you need further assistance.
May 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
