I am trying to set times for heating to go on and off
  • 400 Answers
I suggest you look online at the manufactures website to download a manual for your thermostat. There are many different types of thermostats and telling you how mine is set may not help you at all. I hope this helps. Have the model number ready when you get online.
Posted on Oct 22, 2013
Focus pro deadband temperature settings. Can I set in auto different temperature 10pm- 6am heating 72 cooling 75 6am-10pm heating 71 cooling 74
The deadband setpoint is the limit of how close your heating temp can be to your cooling temp. I believe you are trying to program your tstat to run at certain times. This would be possible if your tstat is programmable. Not sure if yours is. But a 3 degree deadband is a good setting. Hope I answered your question!!
Apr 14, 2017 | Heating & Cooling
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
I have gw71b microwave purchased 5 days back as i opened it and startedto heat my milkits not getting hot tell me how to use it tomake heat
Microwave ovens heat by the tie that is selected. If you set the length of time to short, it want heat well. If you set it to long, it can cause liquid to boil over or burn food. Not knowing how many ounces of milk you're trying to heat, makes it difficult at best, to tell you how much time to set it for. My best advice, since you just purchased it, I assume that it's new, is to read the Owners Manual and always use microwave safe containers.
Mar 04, 2011 | Heating & Cooling
I dont know how to use induction cooker.it has no numbers to reduce the heat.things will burn very fast
You can use to set the timing in order of the heat required. Also using the grade rating of the heating coupled with the time set, the food can be easily heated without burning.
To start with use low heat and long time, the try with medium heat and lesser time and then choose high heat and short time. You must be able to use the settings accordingg to your requirement.
Hope this advice helps
Aug 27, 2010 | Microwave Ovens
Honeywell ST6400C central heating programmer fault
you may vae to enter a different "Mode" to change the time....also try removing the batteries for 10 minutes and then reprogram the thermostat again
Oct 25, 2009 | Honeywell Electronic Programmable...
User manual for Honeywell ST6400C
Honeywell ST6400C
Times set on thermostat does not turn on or off the heating or hot water at the set times, but any time of the day
Sep 17, 2009 | Honeywell Electronic Programmable...
My remote wont select heat
try checking other settings if it is playing up on other settings it maybe the main PCB on the indoor unit.
* NOTE that it may be the same problem with only the heating setting playing up.
check that it's not cooling when on heat if so the reversing valve coil maybe faulty.
Jun 30, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
HI, MY ELECTROLUX SINGLE FAN OVEN EBO5665 DOES NOT HEAT UP TO ANY TEMP. THE OVEN IS ON, FAN ON,AND THE TIMER DIALS ARE SET. DOESNT HEAT UP. IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME. ANY SUGGESTIONS!...
You probably have a bad ( or open ) heating element.. With the power removed.. look at the heating element and make sure it is connected properly and if after you check that it looks ok.. plug it in and try again.. if it fails to get hot..its probably bad.. Not sure what you mean when you say ' IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME' but if it tripped the switch or circuit breaker .. your heating element may be shorting out to ground.. and would need to be replaced anyway... Hope that helps.
Aug 22, 2008 | Electrolux EOB5600 Ultrafan Electric...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
