Question about Fisher and Paykel Washing Machines
South africa Hi I would like to know if there are any fisher and paykel distributers in south africa that could assist in getting a replacement smart drive motor Much thanks, Steven layne
    Champion:
  • 242 Answers
I just had a search out of curiosity, and I cannot find one. just try calling any old repair guy, it's always possible they have hoarded some parts from F+P machines or know where to look.
Posted on Nov 11, 2013
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Posted on Jan 11, 2008
  • 69 Answers
SOURCE: How to I get to the pump on my Fisher & Paykel
If machine has water in it, bucket out as much as you can.
To access pump:
-Pull machine forward and lean it backwards so you can access under machine.
-On the front right hand side, you will see a fan blade- this is the drain pump. This fan blade should spin freely if you turn it by hand.
-To remove pump: remove plug connection that has 2 wires. Remove other plug connection that has 1 wire. On the top of the pump assembly, you will see a white plastic tag, about a 40mm long horizontally across the pump- gently pull tag towards you, and turn complete pump unit anti clockwise- whole pump will drop out (don't force it, it should come out easily) *Note* if there is water in machine still, it will come out when you remove pump assembly- be ready with some towels!!
-Check pump impellor(blade on other end of pump) is free from obstruction, and turns easily. Check with your finger to see if there is any obstruction in the hole where the pump has come out of (inside bowl).
-You can test pump with an ohm meter (should be approx 37ohms from memory)
Reassemble and test for leaks etc
Posted on Aug 11, 2009
  • 155 Answers
SOURCE: Our Fisher and Paykel 603 smart drive has stopped
most likely your problem is your lid switch visit your local spare parts dealer and purchase a new one
Posted on Feb 06, 2010
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
I'm a bio-engineer at universitas hospital in bloemfontein, south africa. I am repairing a couple of cosycot IW931 models which all show error 17. what does this refer to and what must be replaced
the cosycot is manufactured by fisher & paykel
contact them direct and find out what the codes refer to
go google and type in--cosycot 1w931 error codes and get the distributors closest to you and get the error codes from them
Oct 05, 2016 | Dishwashers
Hi where can I get a instruction manual for my washing machine
go google and type in -- owners manual for ( make and mode ) fisher and paykel washing machine
if it is available there will be a pdf version down load
Oct 26, 2015 | Fisher and Paykel Washing Machines
South africa
Fisher and Paykel have a 24hour help desk. Source the number, have your model and serial number handy and they will be able to sort you out.
Feb 14, 2014 | Fisher and Paykel Kitchen Ranges
Live south africa
No they are not they are junk Always braking and costing a lot of money when they do brake
Sep 04, 2013 | Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
After replacing a hot water hose on my Fisher & Paykel Smart Drive 603, the machine now needs to be rre-set I think. Where would I find that button please??
Hi just read your posting.Why do you think the machine needs to be reset?Is the machine working?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
May 20, 2011 | Fisher and Paykel Fisher & Paykel Washer
I need a new oven thermostat for my Fisher and Paykel free standing range. I am unable to locate this in South Africa and email to Fisher and Paykel remains unanswered.
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 08, 2011 | Fisher and Paykel Kitchen Ranges
Smart drive
hi - does the control panel light up as normal? If it does, and everything else is working of sorts, then it is likely a motor is burnt out and you will need someone to come and investigate / replace it.
May 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Smart Drive 601 - won't turn on
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
Thanks
Jaf
Jan 17, 2008 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
