The remote for the Jensen JE 3211 TV does not work all the time. It more often than not it won't communicate with the TV. This TV is in the motorhome. Batteries are good.
IrishDruid
  • 2712 Answers
SOURCE: tv universal remote/jensen surf series sc330
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • 10865 Answers
SOURCE: Remote won't control the TV
Time warner will swap you for anew one. Call them and find out where to take yours for a swap.
Posted on Apr 11, 2009
  • 25 Answers
SOURCE: Our son dropped our Jensen Universal Remote, the
Manually turn on the component you want to
program.
Find the three-digit code numbers for the
component brand.
Hold the Device key down until the green
indicator light comes on.
Release the Device key. Within 30 seconds,
enter in the three-digit code number. The light will flash when the right code has been entered.
press the Power key. If the component turns
off, you have found the right code.
Send me a mail get your tv code
Posted on Feb 18, 2010
ercupa190
  • 12223 Answers
SOURCE: Remote hand control won't turn system on. Batteries are OK
1) Change by new batteries type alkaline
2) Clean the contacts batteries with special spray contacts cleaner
3) Retight the springs contacts batteries with plier very well for good contacts.
4) Resolder wires contacts batteries.
5) Reset the code again download for free from www. fitness.manualsonline.com or www. remotecodelist.com
Otherwise you must opent the remote and clean any contact from keypads very well, or go to the repair shop
God bless you
Posted on May 15, 2012
gopakumarg43
  • 74383 Answers
SOURCE: remote won't work
Just try a cleaning. For more details, just type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
Posted on Jun 05, 2012
I have a jensen Je 1911 dvdc, it will not stay on but 8 seconds help we have 8 days left
Jensen 19" 12-Volt TV/DVD - Camping World
www.campingworld.com > ... > TVs & Accessories > TVs
Rating: 2 - β€Ž2 votes - β€Ž$269.00 - β€ŽIn stock
Where does one get a replacement remote for the 19 inch /dvd model ??/. 1 answer(s)... Need remote replacement for Jensen JE1911ABC. 1 answer(s).
JENSEN LCD TV Accessories - Jensen RV Direct
www.jensenrvdirect.com > Products > LCD TVs
Items 1 - 12 of 22 - We also offer video control centers, PAL tuners, and digital tuner boxes which will convert your analog TV signal into a digital one.
postheadericon JENSEN JE1914DVDC DVD STAND
dynastre.tk/469748/dvd-jensen-je1914dvdc-stand
Dec 27, 2015 | Jensen Televison & Video
What are the codes to program the jensen remote to a sony tv?
to manually let the remote find the code as i couldnt find the actual sony code since you didnt list your tv try this proceducure
Turn on your tv manually.
Hold on to the (tv) button and on/off button for the same time for 3 secs.
On/off button will light up.
Push on/off button until the tv turns off. up to 30 or so times
Then push the stop button on the bottom of the remote tosave the config.
please let me know if that works
Mar 17, 2011 | Jensen 143307 Remote Control
Need to set up remote to work with Zenith 32 inch flat screen tv which I don't have the code for.
wat moet ik dan doen om de lexmark x2350 teinstaleren op windows 7 kun je me daar bij helpen dan bijvoorbaad dank afz wout
Jan 13, 2010 | Jensen JR500 Remote Control
How to switch between tv and vcr dvd or wii?
bonjour j ai le meme remote que la photo ici Jensen ,,, avec le boutton orange, j ai perdu le code pour la television et celui du VCR,,,comment je fait pour le recuperer j ai pas mon livre non plus tout perdu en demenageant et le tout es encore neuf ma television es une Memorex mon VCR un Sanio pouvez vous m aider svp merci ,,,, mon adresse mail,( passionflakes@hotmail.com )
Oct 25, 2008 | Jensen 143307 Remote Control
Jensen (143307) Remote Control
Turn on your tv manually. (without remote)
Push on/off button until the tv turns off. (1x-10x)
Then push the stop button on the bottom of the remote to save.
Dec 08, 2007 | Jensen 143307 Remote Control
Remote Control Help
ON YOUR REMOTE CONTROL PRESS THE MENU BUTTON THEN GO TO AUDIO - CAPTIONING - OFF THIS SHOULD REMOVE THE CAPTIONING. LET ME KNOW IF I WAS ANY HELP...
Jun 21, 2007 | Jensen JER-422 Universal Remote Control
Programming codes
This link has the manual: http://nostrings.info/JR500/index.html
Feb 24, 2007 | Jensen JR500 Remote Control
JENSEN 323
Here are some of the codes still looking for manual
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
samsung codes is 1004,1005,1006,1012,1013,1015,1017,1019
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Jan 13, 2007 | Jensen 143307 Remote Control
Universal remote
the universal remotes work fine in any tv, but limited to basic funcion, if you whant full funcion one, go to, www.remotes.com or call 1-800-remotes..good luck
Aug 10, 2006 | Jensen TS2050J 20" TV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
