Question about 4113LX 1Button Remote Start System with Unlocking
Where is the program switch and control module on 2007 Hyundai tuscon?
  • eric tress
    eric tress Oct 15, 2013
    I'm not following what you mean by lock and unlock. I'm looking where is the control module and the programming switch?
  • eric tress
    eric tress I'm not following what you mean by lock and unlock. I'm looking where is the control module and the programming switch?
  • 3 Answers
Lock and unlock
Posted on Oct 14, 2013
Where is the DRL Module on my 2007 Hyundai Tuscon
How to disable DRL (Daytime Running Lights) - TucsonDrivers.com
tucsondrivers.com/viewtopic.php?t=1809
Oct 17, 2006 - I wonder why Hyundai didn't put it on the US models? ... I wish my Tucson had daytime running lights. ... The DRL module on the Tucson in Canada basically puts 12 volts on ... #8 Postby Hermine ยป Wed Jun 20, 2007 5:39 pm.
Daytime Running Lights (DRL) not working =( - Hyundai Forum ...
www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Accent
Apr 25, 2008 - Join Date: May 2007 ... Basically, I've noticed my DRL are no longer working. ... Does anyone know what does the DRL module looks like and where I could find it? ... 04 Daytime running lights, CaptAthlon, Hyundai Elantra, 9 ...
Nov 24, 2015 | 2007 Hyundai Tucson Limited
HOW PROGRAM THE KEY LESS ENTRY FOR SONATA 2012
  1. Cars
  2. Car Maintenance
  3. General Car Maintenance
  4. How to Program Keyless Entry Remotes in a Hyundai Sonata
How to Program Keyless Entry Remotes in a Hyundai Sonata By Christian Killian, eHow Contributor
20Found This Helpful The keyless entry system in your Hyundai Sonata is part of the factory alarm system. If you have to replace a lost or damaged remote, reprogramming will be necessary. The remote is important because not only does it lock and unlock the doors, it also arms and disarms that factory alarm when you open or close your car doors. New remotes are available from any Hyundai dealer. While they will program it for you, you can do it yourself and save a programming fee.
How to Program Keyless Entry Remotes in a Hyundai Sonata(Kleophaus Livingston/Demand Media)
Other People Are Reading
Step 1: Locate the fuse panel under the dash on the driver's side of the car. Just below it is the control module for the factory alarm system. Open the cover on the alarm system control module and locate the memory switch inside.
(Kleophaus Livingston/Demand Media) Step 2: Verify that the switch is in the "Off" position; if it is not, switch it to the "Off" position. This is important for the system to understand what you want it to do when you move to the programming mode.
(Kleophaus Livingston/Demand Media) Sponsored Links
Step 3: Insert the key into the ignition of your Sonata and turn the key to the "On" position. Wait for 60 seconds, then move the memory switch inside the control module to "Set."
(Kleophaus Livingston/Demand Media) Step 4: Depress and hold the "Lock" button on your remote for one full minute. This allows the remote and the control module to communicate and sync. Release the "Lock" button and turn the memory switch in the control module back to the "Off" position.
(Kleophaus Livingston/Demand Media) Step 5: Turn the ignition switch to the "Off" position and test the remote by pressing the "Lock" or "Unlock" button, verifying that the doors do lock or unlock.
Read more : http://www.ehow.com/how_6362326_program-entry-remotes-hyundai-sonata.html
Mar 29, 2015 | Hyundai Sonata Cars & Trucks
How many miles do you get out of a set of plugs on 2007 Hyundai tuscon
you should get at least 10,000km out of standed plugs.
Dec 29, 2014 | Hyundai Cars & Trucks
2005 Hyundai Tuscon with the check engine light is on. The car is running fine. I had just put gas in it. The gas cap is securely fastened. I took it in for an oil change. The light still plagues me.
When a 'check engine light' (MIL=Malfunction Indicator Lamp) is turned on, there is a DTC (Diagnostic Trouble Code) set/stored in the ECM/PCM (Engine Control Module/Powertrain Control Module). This code identifies which engine management system component/function experienced a malfunction. Once you pull/read this code, you may begin diagnosis.
Sep 03, 2011 | 2005 Hyundai Tucson
I need code for tuscon 07 radio can anyone help
www.unlockmycarradio.info you'll probably going to need to contact Hyundai and find out if it has a radio code. The 2007 model year had the option for security code on the Upgraded stereo package. Hyundai may need your radio's serial number to determin if it comes with a lockout. Usually the stereo's serial number is printed on the botom or back of the stereo chassis.
Mar 31, 2010 | Radio Communications
Hyundai Tuscon 2007 commercial 2.0L Diesel. Water dropping down on passenger side above feet. I think it is something to do with Air Con.
perhaps... could be condensation from use of the Air Conditioning... could be something else... could be a number of things... can't diagnose this problem without 'direct inspection.'
Jun 24, 2009 | Hyundai Tucson Cars & Trucks
Program factory remote keyless entry: 2003 Hyundai XG350
The procedures you list require the Hyundai Keyless Remote programming module, which you don't have. This module is proprietary - only Hyundai Dealerships have it. There is a 10 pin connector under the dash (next to the DLC - Data Link Connector) which is used to connect the Keyless Remote Programming Module. This module has two switch positions "Ready" and "SAVE". When the switch is place in the 'SAVE" position, that's when the keyless remotes are activated to send their 'codes' to the Electronic Time and Control System (ETACS). The module's switch is then set to "Ready" and the remote is tested to see if it works properly.
May 22, 2009 | Hyundai Motor 2003 XG350
Program factory remote keyless entry 2003 Hyundai XG350
I've informed you of what you need to do. Take the veh into a Hyundai Service Center - let them program the remotes.
Programming factory remote on 2003 Hyundai XG350
Again, the remotes can only be programmed by a Hyundai Technician (ETACS - Electronis Time and Alarm Control System).
4113LX 1Button Remote Start System with Unlocking Logo
60 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Morgan Kane
Level 1 Expert
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
