Question about Husqvarna Garden
Break will nor go back on, seems to be stuck.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
The first thing I would try is a good cleaning. Remove the bar an chain and clean really well inside. I use a brush and brake cleaner.
Posted on Oct 14, 2013
Problem Starting Mower
if the brake cable does not disengage the brake all the way the pull cord will not work properly.It will seem stuck.
Apr 02, 2015 | Gcv160 Gas Engine
Gear shift stuck in park
You should take your car back to the person or place that you fixed it and tell them it is worse than before. Insist on getting your money back if it is not fixed.
Jul 12, 2017 | Ford F-250 Cars & Trucks
2004 Kia Sorrento
Is the handle at the seat?
May 19, 2013 | Cars & Trucks
Problem chain / break cover chainsaw
Hi, hold the cover in a vice where the bar nuts normally tighten up to, then pull the chainbrake lever back in the direction the handle bar would be. You will feel a click and the lever will stay back and the brake band will be released. Then refitted cover to the saw. Regards Phil.
Aug 20, 2012 | Garden
Can't get rear wheel bolt to come out. Seems to be stuck in belt side collar. Any one have any ideas.
If you can first turn it to break it loose. If it still stuck put the nut back on partially and using a soft metal hammer like a Brass hammer turn with one hand and with the other hand used a hammer to hit the nut. If this doesn't work you can use a torch to heat the stuck area, be careful you don't burn seals or damage other parts with the torch. Good luck.
Jun 15, 2010 | Motorcycles
Brakes problem 1996 Toyota 4Runner 6 cyl Four
When you said, the bleed valve had to be loosed before the caliper would release, (caliper is already replaced), then we know there was a lot of preasure in the braking lines backed up some where,
and every time the brakes are applied to compress the the caliper to stop your truck,
the preasure would not release,
This
Is a clear indication that the Flexible Rubber Brake Hose attached to the caliper is backed up, clogged, kinked, etc..
That would be the next item in the brake system to check.
Its Bottom Up Disagnostics...
When the hose is off try to slide a strong piece of wire (metal clothes hanger) through the hose..
SOLUTION:
Replace Rubber Brake Line's, on both sides.
I reccomend Stainless Steel Braided Brake Line.
Here is a video that kinda shows corrosion in a rubber hose.
Also check out other videos on youtube.
Feb 27, 2017 | 1996 Toyota 4Runner
How do I get the black cartridge printer out of my mx310 to replace it? Seems stuck and I don't want to break anything!
First you want to open the cover ,the ink cartridge holder will move into a position then stop it is now in the position to remove your ink cartridges !Now you want to press down on the semi-circular tab to release the carthridge and then remove it.It might seem stuck in there give it a little pull don't worry you wont break anything remember when there were installed they had to snap in....
Sep 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Right front wheel seems to stick when vehicle is in drive.
does it feel like its draging when you try to back up? and what do you mean by center bolt? do you mean the big nut on axel in center of wheel? i am going to take a guess here and say its the break caliber piston, where the break pads are, is not releasing from break rotor. witch means its like you got the breaks on. jack wheel off the ground and see if you can spin the wheel by hand. if you cannot spin it that might be it. you also said you tighten axel nut (at least i think thats what you ment)tells me maybe something else is going on here like axel bearing is tied up witch can happen too. when you get wheel off ground and it will not turn by hand pull wheel off and try to push caliber piston back in with a large screwdriver wedge it between the pad and rotor. sould go back fairly easy, you don't have to go back a whole lot just anought to get a gap between rotor and pad then see if you can turn it, if not then it must be wheelbearing. if wheel turns after you do this than caliber is bad and needs replaced. its not stuck in 4x4 even if it was it would not be doing what you discribed.hope this helps.
Jan 14, 2009 | 1998 Chevrolet K1500
Garden Logo
21 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
