Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
The break is jammed or stuck and will no go back on chainsaw
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
No it's engaged... you need to disengage it
Posted on Oct 20, 2013
My poulan chainsaw 3416 has a throttle that is stuck/locked in the run position and also the choke will not stay pulled out ?
The throttle is a simple plastic lever that moves a rod bent in a weird configuration to align and connect to the carbuetor's shaft. Turn the saw upside down and look under the end of the handle, there should be a cap screw, either phillips, allen or torx that releases the back of the handle. Lift it gently and remove the other end from the plastic clips that secure it. Under there you will see the problem...either jammed with debris or just jammed up period. The choke should be a simple plastic affair whose issue could be related to the throttle linkage interfering with its operation. Solve the easiest first then look at the other problem.
Jan 19, 2015 | Poulan Garden
Why is chainsaw running with high revs
Anon it sounds like the choke has stuck out or the accelerator trigger is jammed.
Aug 31, 2014 | Garden
Break will nor go back on, seems to be stuck.
The first thing I would try is a good cleaning. Remove the bar an chain and clean really well inside. I use a brush and brake cleaner.
Oct 13, 2013 | Husqvarna Garden
Problem chain / break cover chainsaw
Hi, hold the cover in a vice where the bar nuts normally tighten up to, then pull the chainbrake lever back in the direction the handle bar would be. You will feel a click and the lever will stay back and the brake band will be released. Then refitted cover to the saw. Regards Phil.
Aug 20, 2012 | Garden
Poulan Wildthing Chainsaw cord stuck/jammed?
are you sure you mixed the gas/oil mixture properly?and if not the engine might have locked up
May 20, 2012 | Garden
Poulan chainsaw rope/cord jammed/stuck
did you mix the gas and oil properly and seize the engine if you did and if its that new bring it back to the store
May 20, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Bit is stuck and cannot remove it. Have tried pretty much everything.
This was posted under chainsaws. If you are asking about a router bit, I have found that taking the collet out with the bit still in it and putting it in a vise. Tap from the bottom with something and it should come out. Be sure to have something underneath to catch the bit. I have done this and had the bit fall and break on the floor...
Please post back if you aren't asking about a router.
Handie Andie
Mar 25, 2011 | Garden
Chain is stuck how do i reset the chain break
pull backward on lever handle in front of wrap handle[handle that doesnt move back or forth] till click safety has reset
Jan 25, 2010 | Ryobi Factory Reconditioned 18" 40cc...
PAPER JAMMED
You have a stuck sensor.
Open the rear door and make sure there is no paper in there.
Remove your toner from the drum and make sure there are no bits of paper stuck under the toner cartridge.
l
Look inside the drum chamber for the little plastic levers that actuate the sensors. Make sure they move back and fourth freely.
Dec 05, 2007 | Brother IntelliFAX 4100 Laser Fax
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
16 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
