Question about AGA Legacy 36" Dual Fuel Kitchen Range
I have an aga with a mk1 1 gas conversion. I turned it off 3 months ago for the summer and have followed the instruction to relight (turn dial to ign point, hold for 5 seconds then turn to ignite) and nothing is happening. I have tried to light the pilot by moving the small glass square but cannot see what I'm looking for and there does not appear to be a smell of gas??? Any ideas
2 Suggested Answers
  • 149 Answers
SOURCE: Aga not lighting
you have an electric head on you BM valve if you turn off the power the valve will shut off if you want it to work with no power i.e. in a power cut you push the lever on the top of the electric head to the left and behind the stop so it doesnt return and the bm valve will be on manual
Posted on Mar 23, 2010
Light pilot light
Many heaters have pilot flames can be relighted with a match or push button operation. Many employ safeguards to prevent unburnt fuel from accumulating in the space or allowing an unstable pilot flame from "proving".
Most appliances have instructions printed or embossed on or near the pilot, gas valve or protective cover. It is very important to closely follow these instructions for your safety and that of others in the area. If you are unable to locate the instructions or follow them and relight the pilot, you should contact the gas company for assistance. This can be in indication of an issue with fuel, thermocouple, gas valve, etc., and would require a service person to correct.
I have included a link to a video to light a gas heater - yours may be the same or similar:
How To Light The Pilot Light On Gas Heater
Feb 23, 2015 | Heating & Cooling
Rheem gas furnace RGMA-125A: How to re-ignite pilot?
did not purge line , you need to purge line as it will take an age with just pilot .
Oct 05, 2012 | Heating & Cooling
How do i relight my hot water system
Natural gas or fuel. turn dial to pilot hold down the button. Light with a long grill match or grill lighter. keep holding button until pilot light stays lit when released. now turn the dial to on.
Apr 01, 2012 | Water Heaters
Put together Endless Summer model 160010 many tears ago only to discover NOT propane. Never used - now have natural gas outlet and will not light ( neither pilot nor main burner) Been on deck summer and...
line could be plugged try clearing , or you could have air in the line which would take ages to come out as pilot is very small , best to purge gas line of air then try and relight
Sep 02, 2011 | Endless Summer Heating & Cooling
Hi there i recently had another gas appliance installed and the gas was turned off while this work was done, so my hot water service pilot light went out. the guys who did this work didn't relight the...
First turn the dial on the hot water heater to the off position and wait for 5 minutes. Then turn the dial on the water heater to the pilot position. Press in the dial and use a gas grill lighter, long wooden match, or similar device to light the pilot. Once the pilot is lit, continue to hold in the dial for about 1 minute then release and turn the dial to the temperature setting that's comfortable for you.
Dec 11, 2010 | Heating & Cooling
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
Aga not lighting
Dec 03, 2009 | AGA Kitchen Ranges
I am attempting to turn on the home central gas heater for the first time this year. It is controlled by a honeywell self ignition model number sv9541. I follow the instructions on the front panel and...
Check to make sure the gas valve is opened. I've turned mine off for the summer months; when I went to use the heater for the first time...I realized I had turned the gas off.
Nov 17, 2009 | Honeywell Programmable Thermostat Heater
Electrolux gas single oven
due to safety feature you should have oven door closed,turn dial to 1,ignite then turn to 5or 6 hold it in for a few seconds and release.this should solve your problem
Jul 27, 2008 | Electrolux EOG6330 Gas Single Oven
AGA Legacy 36" Dual Fuel Kitchen Range Logo
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Paul Carew
Tom Chichester
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
